Ana içeriğe geç
How to Repair Scratches in Laminate Finish Furniture
Shelby
Shelby ve başka bir katkıda bulunan
En son May 28, 2024 tarihinde güncellendi
3 saat
Kolay
This guide will show you how to repair any scratches that might appear on your laminate finish furniture. This method can be used for both shallow and deep scratches and involves using a wood filler product to repair damage. Wood filler comes in a variety of colors so pick one that best matches your furniture, or color match with paint.
This guide will help you improve the appearance of your furniture and extend the use of the piece.
  1. How to Repair Scratches in Laminate Finish Furniture, How to Repair Scratches in Laminate Finish Furniture: adım 1, 1 resimden 1.
    • Clean the scratched area with a damp cloth or paper towel to remove any dust or debris.
  2. How to Repair Scratches in Laminate Finish Furniture: adım 2, 1 resimden 1.
    • Apply a small amount of wood filler to a putty knife.
    • The amount of wood filler needed may vary depending on severity of the scratches.
  3. How to Repair Scratches in Laminate Finish Furniture: adım 3, 1 resimden 1.
    • Spread the wood filler over the scratches using the putty knife until they are sufficiently filled in.
    • The putty knife can be used to scrape away excess wood filler and smooth the surface.
  4. How to Repair Scratches in Laminate Finish Furniture: adım 4, 1 resimden 1.
    • Wipe away any residual wood filler from the surface using a damp cloth or paper towel.
  5. How to Repair Scratches in Laminate Finish Furniture: adım 5, 1 resimden 1.
    • Allow the wood filler to dry completely based on the package instructions before resuming use.
  6. How to Repair Scratches in Laminate Finish Furniture: adım 6, 1 resimden 1.
    • Sand over the wood filler using fine-grit sandpaper if a smoother finish is desired.
  7. How to Repair Scratches in Laminate Finish Furniture: adım 7, 1 resimden 1.
    • Paint over the wood filler, if desired, to color match the filler with the furniture.
    • Wood filler comes in a variety of colors so painting may not be necessary.
Bitiş Çizgisi
Shelby
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 64
Her zaman: 371
