Ana içeriğe geç
How to Repair a Frayed Headphone Cable
Tyler
Tyler ve 12 diğer katkıda bulunanlar
En son August 27, 2024 tarihinde güncellendi
15 - 25 dakika
Orta
Tired of replacing old headphone sets? Here’s a step-by-step guide on repairing frayed headphone cables in an environmentally efficient and affordable way. This guide will require soldering skills.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. How to Repair a Frayed Headphone Cable, How to Repair a Frayed Headphone Cable: adım 1, 2 resimden 1. How to Repair a Frayed Headphone Cable, How to Repair a Frayed Headphone Cable: adım 1, 2 resimden 2.
    • Cut above the frayed portion of the cable using wire cutters.
    • Using the wire cutters, strip away approximately one inch of wire coating.
    • Use caution to avoid cutting too far into the wire.
  2. How to Repair a Frayed Headphone Cable: adım 2, 2 resimden 1. How to Repair a Frayed Headphone Cable: adım 2, 2 resimden 2.
    • After stripping the wire, four wires should be exposed. The wires should be three different colors.
    • Red: Right channel
    • Gold/copper: Ground
    • Blue/green: Left channel
    • Twist the two ground wires together.
    Wait, so which one is left? You said right twice
    bleepbloopimarobot - Yanıt
  3. How to Repair a Frayed Headphone Cable: adım 3, 2 resimden 1. How to Repair a Frayed Headphone Cable: adım 3, 2 resimden 2.
    • Unscrew the plug housing.
    • Thread the wire through the plug housing.
  4. How to Repair a Frayed Headphone Cable: adım 4, 1 resimden 1.
    • Remove the enamel from the red and blue wires with a wire stripper.
  5. How to Repair a Frayed Headphone Cable: adım 5, 1 resimden 1.
    • With a soldering iron, apply a small amount of solder to the end of each wire.
    • This is especially important for the twisted ground wires; the solder should hold them together.
  6. How to Repair a Frayed Headphone Cable: adım 6, 3 resimden 1. How to Repair a Frayed Headphone Cable: adım 6, 3 resimden 2. How to Repair a Frayed Headphone Cable: adım 6, 3 resimden 3.
    • Thread the wires through each hole and wrap them back over.
    • See the third picture for a diagram of where each wire goes.
    • Next, twist each wire with itself to secure it to the lead. This can be seen in the second picture.
  7. How to Repair a Frayed Headphone Cable: adım 7, 2 resimden 1. How to Repair a Frayed Headphone Cable: adım 7, 2 resimden 2.
    • Solder over each lead's hole, connecting the wire to the lead.
    • Your solder joints should completely cover the hole and surround the wire.
    • After each wire is connected, use a drop of hot glue to secure the wires and prevent them from touching each other.
  8. How to Repair a Frayed Headphone Cable: adım 8, 1 resimden 1.
    • Screw the housing back onto the jack and test your work.
    • If the sound turns on and off this is a connection error. To fix it, look at your solder joints and make sure the wires are fully connected to the leads. If not, apply more solder to the joints, covering the wire.
Bitiş Çizgisi
36 farklı kişi bu kılavuzu tamamladı.
Tyler
846 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 23-2, Green Winter 2015 Cal Poly, Team 23-2, Green Winter 2015 üyesi
CPSU-GREEN-W15S23G2
4 Üyeler
18 adet Kılavuz yazıldı
2Kılavuz Yorumları
To me, the more difficult part in this job, is solder.... Now, If you are not sure, with where solder each wire, try with a tester in the continuity mode, and test between the each part of the tip and the three holes. Greetings!
Anderson Barreto - Yanıt
great instruction - any for repair of cable with microphone ? and even a flat cable ?
LiveVest - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 21
Son 7 gün: 96
Son 30 gün: 494
Her zaman: 120,126
