Ana içeriğe geç
How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing
Neye ihtiyacın var
  1. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing, Cotton Winter Gloves: adım 1, 2 resimden 1. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing, Cotton Winter Gloves: adım 1, 2 resimden 2.
    • Find the hole in your glove.
  2. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 2, 1 resimden 1.
    • Using sewing scissors, cut away any loose thread or frayed sections.
    • Removing loose thread or frayed sections will help the sewing process be easier.
  3. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 3, 1 resimden 1.
    • Turn the glove inside out.
    • When the glove is turned inside out, it will ensure that the stitching from the repair won't be seen on the outside.
  4. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 4, 1 resimden 1.
    • Cut about 24 inches of thread with a color that matches your gloves.
  5. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 5, 1 resimden 1.
    • Hold the needle with your thumb and index finger.
    • Insert one end of the thread into the eye of the needle.
    • Pull the thread through the needle about halfway.
    • Working with sewing needles can potentially result in a minor injury.
  6. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 6, 2 resimden 1. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 6, 2 resimden 2.
    • Find both ends of the thread.
    • Line the ends of the thread together.
    • Create a knot at the end of the thread.
  7. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 7, 1 resimden 1.
    • Using your dominant hand, insert the needle as close to the edge of the hole as possible.
    • Pull the needle and all of the thread through the glove.
  8. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 8, 2 resimden 1. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 8, 2 resimden 2.
    • Thread the needle to the other side of the glove to create a straight stitch.
    • Repeat steps 7 and 8 until you reach the other end of the hole.
    • How to Sew a Straight Stitch
  9. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 9, 1 resimden 1.
    • Insert 3/4 of the needle into the glove.
  10. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 10, 1 resimden 1.
    • Wrap the thread around the needle 3 times.
  11. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 11, 1 resimden 1.
    • Pull the needle and thread through to make a knot.
  12. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 12, 1 resimden 1.
    • Cut the excess thread off.
  13. How to Repair a Hole in Cotton Winter Gloves by Hand-Sewing: adım 13, 1 resimden 1.
    • Turn the glove around and wear the glove!
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I found a typo.
On step 8, it says, "Thread the needle to the other side of the glove." This doesn't make sense. Did you mean PUSH the needle?
You already covered threading the needle in step 3. It's not possible to "thread a needle to the other side" of something.
Jean - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 39
Her zaman: 3,530
