Ana içeriğe geç
How to Repair a Hole in a Duvet Insert
Ben Arnold-Galati
Ben Arnold-Galati ve 2 diğer katkıda bulunanlar
En son February 21, 2025 tarihinde güncellendi
5 - 10 dakika
Kolay
Daha iyi giriş
Öğrenci İş Başında
This is an easy step-by-step guide on how to repair a hole in a duvet insert. Through this guide, you will use a patch of scrap fabric to repair the hole in order to achieve the most secure repair possible on a very frequently used item. Though there is no specfic way that a hole might appear in a duvet cover, it can often causes problems with leaking feathers or enlarge even more if not repaired. When following this tutoiral, it will be beneifical to have proir knowledge on how to thread a needle and a general knowledge on how to sew. Though the stitches do not have to be pretty or very even, it will be easier to understand the process of the repair with such knowledge. Have fun fixing!
  1. How to Repair a Hole in a Duvet Insert, How to Repair a Hole in a Duvet Insert: adım 1, 1 resimden 1.
    • Remove the duvet cover from the insert and locate the hole.
  2. How to Repair a Hole in a Duvet Insert: adım 2, 1 resimden 1.
    • Cut a piece of scrap fabric slightly larger than the hole.
  3. How to Repair a Hole in a Duvet Insert: adım 3, 1 resimden 1.
    • Insert the fabric inside the hole, making sure the fabric covers the entirety of the opening.
  4. How to Repair a Hole in a Duvet Insert: adım 4, 1 resimden 1.
    • Carefully pin the patch in place, ensuring the entire opening is covered and secure.
  5. How to Repair a Hole in a Duvet Insert: adım 5, 1 resimden 1.
    • Insert thread in the needle hole and tie a slip knot at the end of the thread.
    • Keep extra thread pulled through the needle to prevent it from unthreading. If it does, re-thread and continue.
  6. How to Repair a Hole in a Duvet Insert: adım 6, 3 resimden 1. How to Repair a Hole in a Duvet Insert: adım 6, 3 resimden 2. How to Repair a Hole in a Duvet Insert: adım 6, 3 resimden 3.
    • Insert the needle in one of the corners of your patch, being sure to pierce through both the duvet insert and patch.
    • Continue stitching around the perimeter of the patch with stitches around 1/4 of an inch long until you have reached your previous starting point.
  7. How to Repair a Hole in a Duvet Insert: adım 7, 2 resimden 1. How to Repair a Hole in a Duvet Insert: adım 7, 2 resimden 2.
    • Sew around the hole's edges to secure the duvet insert into the patch to prevent future tearing.
  8. How to Repair a Hole in a Duvet Insert: adım 8, 3 resimden 1. How to Repair a Hole in a Duvet Insert: adım 8, 3 resimden 2. How to Repair a Hole in a Duvet Insert: adım 8, 3 resimden 3.
    • Once finished, tie 1-2 knots and cut the thread off.
    • Make sure to leave 1/4 inch between the cut and the knot to prevent the knot from coming undone.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Ben Arnold-Galati
187 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 3-3, Vidal-Chiesa Fall 2024 UC Davis, Team 3-3, Vidal-Chiesa Fall 2024 üyesi
UCD-VIDAL-CHIESA-F24S3G3
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 80
