Ana içeriğe geç
How to Repair a Squareplug Patch Cable with SP400 Plugs
Neye ihtiyacın var
  1. How to Repair a Squareplug Patch Cable with SP400 Plugs, Patch Cables With SP400 Plugs: adım 1, 1 resimden 1.
    • Verify that the cable is faulty (unresponsive yellow and green LED indicators).
    • Yellow LED indicator
    • Green LED indicator
    • If both the yellow and green LED indicators turn on, then the cable is not the source of any audio loss. Check the pedals, amp, guitar, or power supply for issues.
    • If the red LED turns on, then the cable is shorting and will also require a resolder.
  2. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 2, 1 resimden 1.
    • Unscrew the SP400 housing.
  3. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 3, 3 resimden 1. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 3, 3 resimden 2. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 3, 3 resimden 3.
    • Desolder the existing solder connections.
    • Wick the existing solder completely off of the plug connections.
    • Do not touch the plug or the wick directly while desoldering.
    • For more information on soldering, check out the How to Solder and Desolder Connections guide.
  4. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 4, 2 resimden 1. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 4, 2 resimden 2.
    • Cut the ends of the cable using a pair of wire cutters to expose fresh wires.
  5. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 5, 3 resimden 1. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 5, 3 resimden 2. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 5, 3 resimden 3.
    • Strip the outer insulating jacket by ~1 cm.
    • The Eclipse UTP Stripper works especially well for this step.
    • Braid the ground wires.
  6. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 6, 3 resimden 1. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 6, 3 resimden 2. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 6, 3 resimden 3.
    • Strip the inner insulator by ~2mm.
    • Braid the signal wires.
  7. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 7, 3 resimden 1. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 7, 3 resimden 2. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 7, 3 resimden 3.
    • Tin the soldering iron tip, ground wire, signal wire, and plug connections.
    • Do not touch the plug or the solder directly while tinning.
  8. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 8, 2 resimden 1. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 8, 2 resimden 2.
    • Solder the wires onto the plug connections:
    • Signal wire to the tip connection
    • Ground wire to the sleeve connection
    • The outer insulating jacket should slightly extend into the chamber of the plug to minimize cable movement.
    • Do not touch the plug directly while soldering.
  9. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 9, 1 resimden 1.
    • Screw the SP400 housing.
  10. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 10, 2 resimden 1. How to Repair a Squareplug Patch Cable with SP400 Plugs: adım 10, 2 resimden 2.
    • Verify that the cable is working (responsive yellow and green LED indicators).
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 883
