Ana içeriğe geç
How to Repair a Stuck or Broken Chainsaw Rope
Neye ihtiyacın var
  1. How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: adım 1, 2 resimden 1. How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: adım 1, 2 resimden 2.
    • Remove the chainsaw casing or handle.
    • This step will vary depending on what kind of chainsaw you are using. Some might only require you to remove the handle, while others have a casing you must remove instead.
  2. How to Repair a Stuck or Broken Chainsaw Rope: adım 2, 1 resimden 1.
    • Remove the screw on top of the housing.
  3. How to Repair a Stuck or Broken Chainsaw Rope: adım 3, 2 resimden 1. How to Repair a Stuck or Broken Chainsaw Rope: adım 3, 2 resimden 2.
    • Remove the housing unit.
  4. How to Repair a Stuck or Broken Chainsaw Rope: adım 4, 2 resimden 1. How to Repair a Stuck or Broken Chainsaw Rope: adım 4, 2 resimden 2.
    • Remove the rope from the chainsaw using a pair of pliers.
  5. How to Repair a Stuck or Broken Chainsaw Rope: adım 5, 1 resimden 1.
    • Make your adjustments to fix any problems with the rope.
    • The adjustments needed to be made will vary depending on your specific problem with the rope.
  6. How to Repair a Stuck or Broken Chainsaw Rope: adım 6, 1 resimden 1.
    • Stick the rope back through the insertion hole.
  7. How to Repair a Stuck or Broken Chainsaw Rope: adım 7, 1 resimden 1.
    • Stick the housing back onto the casing.
    • Do not screw the housing on yet.
  8. How to Repair a Stuck or Broken Chainsaw Rope: adım 8, 1 resimden 1.
    • Twist the housing unit until the tension is maxed out.
    • Caution: Once the tension is maxed out, you must hold the housing unit firmly or else it will slide out and possibly hit you or someone nearby.
  9. How to Repair a Stuck or Broken Chainsaw Rope: adım 9, 2 resimden 1. How to Repair a Stuck or Broken Chainsaw Rope: adım 9, 2 resimden 2.
    • Stick the rope through the groove into the housing.
  10. How to Repair a Stuck or Broken Chainsaw Rope: adım 10, 1 resimden 1.
    • Re-tie the rope into a knot.
  11. How to Repair a Stuck or Broken Chainsaw Rope: adım 11, 2 resimden 1. How to Repair a Stuck or Broken Chainsaw Rope: adım 11, 2 resimden 2.
    • Slowly rewind the housing unit until the rope is back into its original position.
  12. How to Repair a Stuck or Broken Chainsaw Rope: adım 12, 1 resimden 1.
    • Re-screw any screws used to take off the housing.
    • This step will vary. Not all chainsaws will have extra screws on their housing unit.
  13. How to Repair a Stuck or Broken Chainsaw Rope: adım 13, 1 resimden 1.
    • Place the casing or handle back onto the chainsaw.
    • Similarly to Step 1, this will vary depending on the type of chainsaw you are using.
  14. How to Repair a Stuck or Broken Chainsaw Rope: adım 14, 1 resimden 1.
    • Pull on the rope to make sure the chainsaw works.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 591
