Ana içeriğe geç
How to Repair the Buttons on a Logitech Pebble Mouse
Emma Whitmer
Emma Whitmer ve 3 diğer katkıda bulunanlar
En son June 21, 2023 tarihinde güncellendi
6 - 10 dakika
Kolay
If you need to repair the buttons on your Logitech Pebble M350/M355 mouse, follow this guide. This guide will show you how to disassemble the mouse to reach the scroll wheel and buttons and apply a small amount of lubricant to them.
Many users of this mouse have encountered a problem where the buttons eventually stop working. Since this isn't ideal for a device you use every day, the purpose of our guide is to provide a simple solution for this common problem.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: adım 1, 3 resimden 1. How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: adım 1, 3 resimden 2. How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: adım 1, 3 resimden 3.
    • Use your hands to remove the magnetic top panel of the mouse.
  2. How to Repair the Buttons on a Logitech Pebble Mouse: adım 2, 3 resimden 1. How to Repair the Buttons on a Logitech Pebble Mouse: adım 2, 3 resimden 2. How to Repair the Buttons on a Logitech Pebble Mouse: adım 2, 3 resimden 3.
    • Remove the USB adaptor in the small rectangular hole on the lower right corner.
    • Remove the battery.
  3. How to Repair the Buttons on a Logitech Pebble Mouse: adım 3, 2 resimden 1. How to Repair the Buttons on a Logitech Pebble Mouse: adım 3, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove one screw holding the inner panel in place.
  4. How to Repair the Buttons on a Logitech Pebble Mouse: adım 4, 3 resimden 1. How to Repair the Buttons on a Logitech Pebble Mouse: adım 4, 3 resimden 2. How to Repair the Buttons on a Logitech Pebble Mouse: adım 4, 3 resimden 3.
    • Remove the the inner panel.
    • This may take a little bit of effort but it should come off fairly easily.
    • You can use the battery socket as leverage to remove the panel. To avoid breaking the panel, be gentle but firm.
  5. How to Repair the Buttons on a Logitech Pebble Mouse: adım 5, 1 resimden 1.
    • Use a fine-tipped object or a Q-tip and dip it in a small amount of oil.
  6. How to Repair the Buttons on a Logitech Pebble Mouse: adım 6, 3 resimden 1. How to Repair the Buttons on a Logitech Pebble Mouse: adım 6, 3 resimden 2. How to Repair the Buttons on a Logitech Pebble Mouse: adım 6, 3 resimden 3.
    • Gently wipe the metal axle where the scroll wheel is mounted with a small amount of 3-in-1 oil.
    • Repeat for the left and right click buttons.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Emma Whitmer
169 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-6, Morris Spring 2023 UC Davis, Team 2-6, Morris Spring 2023 üyesi
UCD-MORRIS-S23S2G6
3 Üyeler
1 Kılavuz yazıldı
2Kılavuz Yorumları
At first i'm laugh about fixing button with oil, but then i tried it... and it worked like a charm!
Marat - Yanıt
I didn't even disassemble (unscrew) my pebble. Just applied a drop of mineral oil to the button and it did help a lot! Thanks!
Tomek Luzak - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 188
Her zaman: 3,362
