Ana içeriğe geç
How to Replace Asus Transformer Pad TF103C Headphone Jack
Tyler Ellis
Tyler Ellis ve 9 diğer katkıda bulunanlar
En son June 27, 2024 tarihinde güncellendi
15 - 30 dakika
Kolay
This guide will lead you through the steps to replace the Transformer Pad TF103C Headphone Jack on your ASUS laptop. It provides you with detailed steps with pictures and requires few commonly used tools. If you follow this guide step by step, then you should be able to replace this part with little to no previous technical experience.
  1. How to Replace Asus Transformer Pad TF103C Headphone Jack, Headphone Jack: adım 1, 1 resimden 1.
    • Turn the power off.
    • Insert the plastic opening tool between the top and bottom covers of the laptop. The two covers are attached all along the outside of the laptop.
    • Use a thin screwdriver if you don't have an opening tool.
    • Gently pull upwards and carefully pry open the bottom and top covers.
  2. How to Replace Asus Transformer Pad TF103C Headphone Jack: adım 2, 1 resimden 1.
    • Slide the tool along all four edges of the laptop and continue to pull the tool upwards to fully remove the bottom case from the laptop.
  3. How to Replace Asus Transformer Pad TF103C Headphone Jack: adım 3, 1 resimden 1.
    • Remove the back cover once it is detached then set it aside.
    • Rotate your laptop to match the orientation shown in the picture to make the guide easier to follow.
  4. How to Replace Asus Transformer Pad TF103C Headphone Jack: adım 4, 1 resimden 1.
    • Remove the tape and unplug the wire that attaches to both speakers from the soundboard.
  5. How to Replace Asus Transformer Pad TF103C Headphone Jack: adım 5, 1 resimden 1.
    • Use the +J000 screwdriver to unscrew and remove the M2 screw and plastic bracket.
  6. How to Replace Asus Transformer Pad TF103C Headphone Jack: adım 6, 1 resimden 1.
    • Remove the black tape from the ribbon cable and separate the cable from the soundboard.
  7. How to Replace Asus Transformer Pad TF103C Headphone Jack: adım 7, 1 resimden 1.
    • Use the +J000 to remove the three mounting screws from the soundboard.
    • Keep the screws together and organized. (Label, if necessary).
  8. How to Replace Asus Transformer Pad TF103C Headphone Jack: adım 8, 2 resimden 1. How to Replace Asus Transformer Pad TF103C Headphone Jack: adım 8, 2 resimden 2.
    • Remove the soundboard which has the headphone jack attached to it and replace with the new soundboard.
    • Once done reassemble your device, follow these instructions in reverse order.
Sonuç
Tyler Ellis
668 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-6, Shastany Fall 2015 UMass Dartmouth, Team 3-6, Shastany Fall 2015 üyesi
UMASSD-SHASTANY-F15S3G6
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 697
