Ana içeriğe geç
How to Replace Field Hockey Stick Grip Tape
Sophia Juan
Sophia Juan ve 3 diğer katkıda bulunanlar
En son May 14, 2024 tarihinde güncellendi
9 - 10 dakika
Kolay
If your Grays field hockey stick, or any similar stick, is worn down- unravelled grip or a detached cap- use this guide to repair the handle of your field hockey stick.
The handle of a field hockey stick assists athletes in performing skills and effectively playing the sport through holding/handling the stick. A broken field hockey stick will interfere with the fundamental skills of the game and negatively affect performance.
Before using this guide, ensure your hands are clean and inspect the stick (curved end). Typically, any significant cracks or holes in the stick are not worth repairing. Ensure that the rest of the stick is intact to make the repair worthwhile.
Tool List + Materials
  • Scissors
  • Gorilla Glue (or alternative brand)
  • Grip Tape
  • Gauze Tape
  1. How to Replace Field Hockey Stick Grip Tape, Grip Tape: adım 1, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape, Grip Tape: adım 1, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape, Grip Tape: adım 1, 3 resimden 3.
    • Use a cloth and an anti-bacterial spray to clean the Field Hockey stick.
  2. How to Replace Field Hockey Stick Grip Tape: adım 2, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 2, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape: adım 2, 3 resimden 3.
    • Unravel the old sticky tape starting from the top of the stick.
  3. How to Replace Field Hockey Stick Grip Tape: adım 3, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 3, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape: adım 3, 3 resimden 3.
    • Unravel old tape until it meets the end of the handle.
  4. How to Replace Field Hockey Stick Grip Tape: adım 4, 2 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 4, 2 resimden 2.
    • Carefully cut the tape so that end of grip tape below can be taken off.
    • Handle scissors with care never holding the open blade.
  5. How to Replace Field Hockey Stick Grip Tape: adım 5, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 5, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape: adım 5, 3 resimden 3.
    • Unravel the old grip tape from the top of the stick that spirals down.
    • Stop unravelling once loose-end cap is exposed fully.
  6. How to Replace Field Hockey Stick Grip Tape: adım 6, 2 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 6, 2 resimden 2.
    • Put glue around the circumference of the base of the loose cap.
    • Line up and press the cap back onto the stick.
    • Handle glue with care so as not to spill.
  7. How to Replace Field Hockey Stick Grip Tape: adım 7, 1 resimden 1.
    • Let the glue dry for at least 10 minutes.
  8. How to Replace Field Hockey Stick Grip Tape: adım 8, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 8, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape: adım 8, 3 resimden 3.
    • Using new gauze tape, re-wrap the stick applying pressure in an upwards motion.
  9. How to Replace Field Hockey Stick Grip Tape: adım 9, 2 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 9, 2 resimden 2.
    • Once new gauze covers the handle, cut the tape from its source.
  10. How to Replace Field Hockey Stick Grip Tape: adım 10, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 10, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape: adım 10, 3 resimden 3.
    • Secure the gauze with sticky tape at the top of the handle.
    • Cut the sticky tape from its source before wrapping around the top of the handle.
  11. How to Replace Field Hockey Stick Grip Tape: adım 11, 3 resimden 1. How to Replace Field Hockey Stick Grip Tape: adım 11, 3 resimden 2. How to Replace Field Hockey Stick Grip Tape: adım 11, 3 resimden 3.
    • Secure the gauze with sticky tape at the bottom of the handle.
    • Cut the sticky tape from its source before wrapping around the bottom of the handle.
  12. How to Replace Field Hockey Stick Grip Tape: adım 12, 1 resimden 1.
    • Enjoy your new grip tape!
Bitiş Çizgisi
Sophia Juan
205 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-5, Andersen Winter 2024 UC Davis, Team 1-5, Andersen Winter 2024 üyesi
UCD-ANDERSEN-W24S1G5
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 222
