Giriş
This guide explains how to replace a chain link fence gate.
Aletler
Parçalar
Spray WD-40 on each hinge bolt. This will make it easier to remove them.
Place blocks on the ground at the where you will install the gate. These will support the gate while you are connecting the hinges.
Lift the gate panel into position so that the gate lines up with the fence and at the desired height. Adjust the blocks as necessary to achieve the desired height.
3 farklı kişi bu kılavuzu tamamladı.
