Ana içeriğe geç
How to Replace a Speaker on a Yamaha PSS-130 Keyboard
Neye ihtiyacın var
  1. How to Replace a Speaker on a Yamaha PSS-130 Keyboard, Internal Speaker: adım 1, 2 resimden 1. How to Replace a Speaker on a Yamaha PSS-130 Keyboard, Internal Speaker: adım 1, 2 resimden 2.
    • Remove the battery cover.
    • Remove all twelve of the 9.0 mm screws on the back cover of the device's casing using a Phillips #1 screwdriver.
  2. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 2, 3 resimden 1. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 2, 3 resimden 2. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 2, 3 resimden 3.
    • Place your fingers in the battery compartment, and place your thumb on the back of the keyboard.
    • Grip inside battery cover and push on the back of the keyboard with your thumb.
  3. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 3, 2 resimden 1. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 3, 2 resimden 2.
    • Replace two 9.0 mm Phillips screws to keep the keys from falling out while working on this device.
  4. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 4, 3 resimden 1. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 4, 3 resimden 2. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 4, 3 resimden 3.
    • Rotate the keyboard to get a better angle with the soldering iron.
  5. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 5, 1 resimden 1.
    • Desolder the connections of the old speaker using the soldering iron and the solder wick.
  6. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 6, 3 resimden 1. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 6, 3 resimden 2. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 6, 3 resimden 3.
    • Remove the fasteners using an 11 mm socket wrench.
    • It will take very little torque to strip the plastic, so make sure that your wrench is turning them to the left.
  7. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 7, 2 resimden 1. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 7, 2 resimden 2.
    • The speaker should now be free. Simply lift the speaker out.
    • Using the same process, place the new speaker in the speaker indentation.
    • My own speaker was not malfunctioning so I did not replace it.
  8. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 8, 1 resimden 1.
    • Replace the fasteners that were removed in step 6, this time tightening to the right.
  9. How to Replace a Speaker on a Yamaha PSS-130 Keyboard: adım 9, 1 resimden 1.
    • Solder the new speaker to the wires taken off in step 5.
Sonuç
To reassemble your device, follow these instructions in reverse order from step 3.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 558
