Ana içeriğe geç
How to Reshell Your Steam Controller (2nd Generation)
Neye ihtiyacın var
  1. How to Reshell Your Steam Controller (2nd Generation), Before you begin: adım 1, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Before you begin: adım 1, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Before you begin: adım 1, 3 resimden 3.
    • Let your controller's battery drain below 25% before starting this repair.
    • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
    • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
    FixBot'a Sor
  2. How to Reshell Your Steam Controller (2nd Generation), Remove the back cover screws: adım 2, 2 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the back cover screws: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    TR6 Torx Security Screwdriver
    $5.99
    FixBot'a Sor
  3. How to Reshell Your Steam Controller (2nd Generation), Remove the back cover: adım 3, 2 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the back cover: adım 3, 2 resimden 2.
    • Remove the back cover.
    FixBot'a Sor
  4. How to Reshell Your Steam Controller (2nd Generation), Remove the battery: adım 4, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the battery: adım 4, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the battery: adım 4, 3 resimden 3.
    • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
    • Lift the right edge of the battery to remove it.
    • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
    FixBot'a Sor
  5. How to Reshell Your Steam Controller (2nd Generation), Remove the mounting bracket screws: adım 5, 2 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the mounting bracket screws: adım 5, 2 resimden 2.
    • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
    • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
    FixBot'a Sor
  6. How to Reshell Your Steam Controller (2nd Generation), Remove the mounting bracket: adım 6, 2 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the mounting bracket: adım 6, 2 resimden 2.
    FixBot'a Sor
  7. How to Reshell Your Steam Controller (2nd Generation), Disconnect the rumble motors: adım 7, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Disconnect the rumble motors: adım 7, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Disconnect the rumble motors: adım 7, 3 resimden 3.
    • Don't pull on the rumble motor's delicate wires—they're easily damaged. Be careful not to pinch the wires with your tweezers, and only pull on the connector itself.
    • Firmly grip the short edges of one rumble motor connector with a pair of tweezers and pull straight up to disconnect it
    • Grip the tweezers as close to the tip as possible to get a better hold on the connector.
    FixBot'a Sor
  8. How to Reshell Your Steam Controller (2nd Generation): adım 8, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation): adım 8, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation): adım 8, 3 resimden 3.
    • Repeat to disconnect the other rumble motor.
    FixBot'a Sor
  9. How to Reshell Your Steam Controller (2nd Generation), Disconnect the interconnect cable: adım 9, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Disconnect the interconnect cable: adım 9, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Disconnect the interconnect cable: adım 9, 3 resimden 3.
    • Be careful not to damage any of the small, surface-mounted components on the main board.
    • Use a spudger to lift the hinged locking flap on the interconnect cable ZIF connector, located on the bottom edge of the main board.
    FixBot'a Sor
  10. How to Reshell Your Steam Controller (2nd Generation): adım 10, 2 resimden 1. How to Reshell Your Steam Controller (2nd Generation): adım 10, 2 resimden 2.
    • Use tweezers to grip the cable by its plastic pull tab and slide it out of the socket.
    FixBot'a Sor
  11. How to Reshell Your Steam Controller (2nd Generation), Remove the main board screws: adım 11, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the main board screws: adım 11, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the main board screws: adım 11, 3 resimden 3.
    • Use a T6 Torx screwdriver to remove the three 7.4 mm‑long screws securing the main board.
    • When reinstalling the screws, raise the controller so the thumbsticks aren't pressed against your work surface—pressure on the thumbsticks can cause improper alignment and seating.
    FixBot'a Sor
  12. How to Reshell Your Steam Controller (2nd Generation), Remove the main board: adım 12, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the main board: adım 12, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the main board: adım 12, 3 resimden 3.
    • Pull the main board down so the top corners clear the triggers.
    • You should be able to remove the board without removing the triggers. If you're having trouble, check out this guide to remove them.
    • Remove the main board, guiding the thumbsticks through their cutouts.
    • During reassembly, make sure the two rumble motor wires don't get trapped underneath the board. Use the four alignment posts to ensure the board is properly positioned.
    FixBot'a Sor
  13. How to Reshell Your Steam Controller (2nd Generation), Rubber piece information: adım 13, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Rubber piece information: adım 13, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Rubber piece information: adım 13, 3 resimden 3.
    • The rubber piece above the status LED may have been dislodged when removing the main board.
    • If the rubber piece is out of place, remove it and set it aside.
    • During reassembly, place the rubber piece so the two tabs are on the bottom and towards the back.
    FixBot'a Sor
  14. How to Reshell Your Steam Controller (2nd Generation), Remove the hinge pin: adım 14, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the hinge pin: adım 14, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the hinge pin: adım 14, 3 resimden 3.
    • With one hand, hold one of the triggers down in the fully actuated position.
    • Don't let go of the trigger, or it will eject and you may lose its spring.
    • With your free hand, use tweezers to pull the hinge pin straight out and remove it.
    • During reassembly, hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted. Test the trigger to ensure the pin was properly installed.
    • When correctly inserted, the pin's end will be aligned with the white rectangle on the board (labelled PIN)—the should be no wobble.
    FixBot'a Sor
  15. How to Reshell Your Steam Controller (2nd Generation), Remove the trigger: adım 15, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the trigger: adım 15, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the trigger: adım 15, 3 resimden 3.
    • Lift the trigger straight up and remove it.
    • Remove the spring and store it in a safe place for reassembly.
    • The spring will either stick to the trigger's magnet or stay on its post.
    FixBot'a Sor
  16. How to Reshell Your Steam Controller (2nd Generation), Remove the other trigger: adım 16, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the other trigger: adım 16, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the other trigger: adım 16, 3 resimden 3.
    • Repeat to remove the other trigger.
    FixBot'a Sor
  17. How to Reshell Your Steam Controller (2nd Generation), Reassembly information: adım 17, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Reassembly information: adım 17, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Reassembly information: adım 17, 3 resimden 3.
    • During reassembly, follow this step to install the triggers.
    • Place one of the trigger springs over its post on the controller.
    • Put the trigger in place, making sure the spring goes over both of its posts (one on the controller and one on the trigger) and that the hinge holes are all aligned.
    • Hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted.
    • If you're having trouble, make sure you're installing the trigger on the correct side.
    • Test the trigger to ensure the pin was properly installed.
    • Repeat to install the other trigger.
    FixBot'a Sor
  18. How to Reshell Your Steam Controller (2nd Generation), Remove the midframe screws: adım 18, 2 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the midframe screws: adım 18, 2 resimden 2.
    • Use a T6 Torx screwdriver to remove the eleven 7.4 mm‑long screws securing the midframe.
    • When removing the screw in the center of the controller, be careful not to damage the plastic button membrane.
    FixBot'a Sor
  19. How to Reshell Your Steam Controller (2nd Generation), Remove the midframe: adım 19, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the midframe: adım 19, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the midframe: adım 19, 3 resimden 3.
    • Lift the midframe straight up and remove it.
    • The buttons and their silicone pads are now sitting loose in their recesses. Be very careful not to flip the front shell, or the buttons will fall out.
    • During reassembly:
    • Check the two large silicone button pads to make sure they're aligned properly and fully seated—if they aren't, button presses may feel off or not register.
    • Use the alignment posts to ensure the midframe is in the right position.
    FixBot'a Sor
  20. How to Reshell Your Steam Controller (2nd Generation), Remove the bumpers: adım 20, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the bumpers: adım 20, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the bumpers: adım 20, 3 resimden 3.
    • Rotate the bumper inwards until you can slide it off its post.
    FixBot'a Sor
  21. How to Reshell Your Steam Controller (2nd Generation): adım 21, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation): adım 21, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation): adım 21, 3 resimden 3.
    • Remove the other bumper.
    • During reassembly, make sure you're installing the bumpers on the correct side.
    FixBot'a Sor
  22. How to Reshell Your Steam Controller (2nd Generation), Disconnect the trackpad cables: adım 22, 2 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Disconnect the trackpad cables: adım 22, 2 resimden 2.
    • Use the flat end of a spudger to lift the hinged, locking flap on one of the trackpad ZIF connectors.
    FixBot'a Sor
  23. How to Reshell Your Steam Controller (2nd Generation): adım 23, 2 resimden 1. How to Reshell Your Steam Controller (2nd Generation): adım 23, 2 resimden 2.
    FixBot'a Sor
  24. How to Reshell Your Steam Controller (2nd Generation): adım 24, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation): adım 24, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation): adım 24, 3 resimden 3.
    • Repeat to disconnect the other trackpad cable.
    FixBot'a Sor
  25. How to Reshell Your Steam Controller (2nd Generation), Remove the FSC board screws: adım 25, 2 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the FSC board screws: adım 25, 2 resimden 2.
    • Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the FSC board.
    FixBot'a Sor
  26. How to Reshell Your Steam Controller (2nd Generation), Remove the FSC board: adım 26, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the FSC board: adım 26, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the FSC board: adım 26, 3 resimden 3.
    • Remove the FSC board.
    • Use the alignment pegs to ensure the board is correctly positioned.
    FixBot'a Sor
  27. How to Reshell Your Steam Controller (2nd Generation), Remove the trackpad screws: adım 27, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the trackpad screws: adım 27, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the trackpad screws: adım 27, 3 resimden 3.
    • The left trackpad will be on your right-hand side, as the shell is upside down.
    • Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the left trackpad.
    • When reinstalling the screws, raise the controller so the trackpad isn't pressed against your work surface. Don't lift too high, or the buttons may fall out.
    FixBot'a Sor
  28. How to Reshell Your Steam Controller (2nd Generation), Remove the trackpad: adım 28, 2 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the trackpad: adım 28, 2 resimden 2.
    • Remove the trackpad.
    • During reassembly, set the trackpad into its cutout so the cable is on the bottom edge. Make sure all the alignment tabs and posts go through their cutouts by the screw holes.
    FixBot'a Sor
  29. How to Reshell Your Steam Controller (2nd Generation), Remove the right trackpad screws: adım 29, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the right trackpad screws: adım 29, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the right trackpad screws: adım 29, 3 resimden 3.
    • Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the right trackpad.
    FixBot'a Sor
  30. How to Reshell Your Steam Controller (2nd Generation), Remove the right trackpad: adım 30, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the right trackpad: adım 30, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the right trackpad: adım 30, 3 resimden 3.
    • During reassmebly:
    • Make sure you're installing the correct trackpad in each recess. There's a small R and L notched into the trackpad and the shell, noting the correct side.
    • Set the trackpad into its cutout so the cable is on the bottom edge.
    • Make sure all the alignment tabs and posts go through their cutouts by the screw holes.
    FixBot'a Sor
  31. How to Reshell Your Steam Controller (2nd Generation), Remove the button membranes: adım 31, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the button membranes: adım 31, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the button membranes: adım 31, 3 resimden 3.
    • Remove the four silicone button membranes.
    FixBot'a Sor
  32. How to Reshell Your Steam Controller (2nd Generation), Remove the buttons: adım 32, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the buttons: adım 32, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the buttons: adım 32, 3 resimden 3.
    • Use tweezers to remove the D‑Pad, View, Steam, Menu, ABXY, and Quick Access Menu buttons.
    • Alternatively, you can flip the front case over and let the buttons fall out.
    • During reassembly, use the alignment tabs to orient each button in its recess. Each one is keyed for proper location and orientation.
    FixBot'a Sor
  33. How to Reshell Your Steam Controller (2nd Generation), Remove the button dampeners: adım 33, 3 resimden 1. How to Reshell Your Steam Controller (2nd Generation), Remove the button dampeners: adım 33, 3 resimden 2. How to Reshell Your Steam Controller (2nd Generation), Remove the button dampeners: adım 33, 3 resimden 3.
    • Use tweezers or a spudger to remove all the button dampeners (they surround the button recesses) from the front shell.
    • During reassembly, transfer the dampeners to your new shell. Use a spudger to push them down so they're fully seated against the shell.
    FixBot'a Sor
  34. How to Reshell Your Steam Controller (2nd Generation), Disassembly complete: adım 34, 1 resimden 1.
    • Congratulations on fully disassembling your Steam Controller! During reassembly, you'll need to transfer all the controller's internals into your replacement shells.
    FixBot'a Sor
Sonuç
Spencer Day
187.930 İtibar
1.187 adet Kılavuz yazıldı
1Rehber Yorum
I am unable to find any pictures anywhere of the inside of the back shell of the 2nd gen. steam controller.
I would like to see how the back buttons are attached to the shell.
Rene Jacobsen - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 30
Son 7 gün: 281
Son 30 gün: 2,222
Her zaman: 2,231
