Ana içeriğe geç
How to Sew a Buttonhole by Hand
Neye ihtiyacın var
  1. How to Sew a Buttonhole by Hand, How to Sew a Buttonhole by Hand: adım 1, 2 resimden 1. How to Sew a Buttonhole by Hand, How to Sew a Buttonhole by Hand: adım 1, 2 resimden 2.
    • Place your button where you want the buttonhole.
    • Use a chalk marker or washable fabric marker to make a vertical line just to the right of the button.
    • Use your marker to make a vertical line just to the left of the button.
  2. How to Sew a Buttonhole by Hand: adım 2, 1 resimden 1.
    • Use your marker to make a horizontal line that connects the two vertical lines.
  3. How to Sew a Buttonhole by Hand: adım 3, 3 resimden 1. How to Sew a Buttonhole by Hand: adım 3, 3 resimden 2. How to Sew a Buttonhole by Hand: adım 3, 3 resimden 3.
    • Sew your first stitch from the top to the bottom of the vertical chalk line on the left.
    • Continue by sewing a running line of small stitches underneath the horizontal chalk line, up the right side, then above the horizontal line.
    • This is the outline for the buttonhole.
  4. How to Sew a Buttonhole by Hand: adım 4, 3 resimden 1. How to Sew a Buttonhole by Hand: adım 4, 3 resimden 2. How to Sew a Buttonhole by Hand: adım 4, 3 resimden 3.
    • Use a seam ripper to poke a hole in the fabric that is large enough for your scissors.
    • Use your scissors to cut a slit along the horizontal chalk line in the middle of your stitched outline.
  5. How to Sew a Buttonhole by Hand: adım 5, 1 resimden 1.
    • Slide your button into the slit to make sure it's large enough.
  6. How to Sew a Buttonhole by Hand: adım 6, 3 resimden 1. How to Sew a Buttonhole by Hand: adım 6, 3 resimden 2. How to Sew a Buttonhole by Hand: adım 6, 3 resimden 3.
    • Bring your threaded needle up through the slit.
    • Push the needle back down through the fabric just to the outside of your first outline stitch.
    • Bring the needle back up through the slit and continue making a row of small, tight, vertical stitches along the bottom edge of the slit.
  7. How to Sew a Buttonhole by Hand: adım 7, 1 resimden 1.
    • When you get to the right edge of the slit, continue by making a small row of horizontal stitches around that end of the buttonhole.
  8. How to Sew a Buttonhole by Hand: adım 8, 2 resimden 1. How to Sew a Buttonhole by Hand: adım 8, 2 resimden 2.
    • Working from right to left, continue sewing small, tight, vertical stitches along the top side of the buttonhole slit.
    • When you get to the left edge, make a row of small horizontal stitches around that end, until you arrive back where you began.
    • Push your needle through to the back and tie it off with a knot.
  9. How to Sew a Buttonhole by Hand: adım 9, 1 resimden 1.
    • Test your new buttonhole and enjoy!
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 51
Son 30 gün: 252
Her zaman: 1,660
