Ana içeriğe geç
How to String a Tennis Racket
Neye ihtiyacın var
    1. How to String a Tennis Racket, Cut the old strings from the tennis racket: adım 1, 2 resimden 1. How to String a Tennis Racket, Cut the old strings from the tennis racket: adım 1, 2 resimden 2.
      • Cut the old strings from the tennis racket using a pair of utility scissors and remove them.
      • Be careful not to cut yourself with the ends of the strings.
      FixBot'a Sor
      Yorum Ekle
    2. How to String a Tennis Racket, Place the frame into a stringing machine: adım 2, 1 resimden 1.
      • Place the frame into a stringing machine by screwing in the four main screws and pulling the racket tight.
      FixBot'a Sor
      Yorum Ekle
    3. How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: adım 3, 3 resimden 1. How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: adım 3, 3 resimden 2. How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: adım 3, 3 resimden 3.
      • Insert the main vertical string into the head of the racket, and thread it down to the neck of the racket and back to the head.
      • Pull and tighten the first main string into a tension rod.
      • The strings should always go under the racquet.
      FixBot'a Sor
      Yorum Ekle
    4. How to String a Tennis Racket, Secure and tighten the end of the string: adım 4, 2 resimden 1. How to String a Tennis Racket, Secure and tighten the end of the string: adım 4, 2 resimden 2.
      • Secure and tighten the end of the string by attaching it to the clamp and moving the rod into the horizontal position.
      • Fix the second string utilizing the second clamp and release the first string.
      • Continue threading the main strings and clamping the strings until all holes have been strung.
      • The stringing pattern: Insert and tighten the string, secure the next string with the clamp, and release the previous string.
      FixBot'a Sor
      Yorum Ekle
    5. How to String a Tennis Racket, Knot the main string: adım 5, 2 resimden 1. How to String a Tennis Racket, Knot the main string: adım 5, 2 resimden 2.
      • Knot the main string after you have secured all the main strings.
      • Release the tension rod and cut off the remaining string.
      FixBot'a Sor
      Yorum Ekle
    6. How to String a Tennis Racket, Horizontal cross strings: adım 6, 1 resimden 1.
      • Insert the horizontal cross strings from the left to the right and back to the left.
      • Secure and tighten the end of the string by attaching it to the clamp and moving the rod into the vertical position.
      • Continue threading the cross strings and clamping the strings until all holes have been strung by applying the stringing pattern.
      • Weave the cross strings by going over and under repeatedly through the main strings.
      FixBot'a Sor
      Yorum Ekle
    7. How to String a Tennis Racket, Knot all the cross strings: adım 7, 1 resimden 1.
      • Knot all of the cross strings after you have secured them.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Tzu-Wei
153 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 49
Her zaman: 5,621
