Ana içeriğe geç
How to True a Bent Bicycle Rim Using Common Tools
Neye ihtiyacın var
  1. How to True a Bent Bicycle Rim Using Common Tools, How to True a Bent Bicycle Rim Using Common Tools: adım 1, 1 resimden 1.
    • Bring your bike somewhere with ample space so you have room to work.
  2. How to True a Bent Bicycle Rim Using Common Tools: adım 2, 3 resimden 1. How to True a Bent Bicycle Rim Using Common Tools: adım 2, 3 resimden 2. How to True a Bent Bicycle Rim Using Common Tools: adım 2, 3 resimden 3.
    • Flip the bike on its seat so the wheel can spin freely.
    • Use the spokes to spin the affected wheel.
    • Continue spinning the wheel until it is clear where the bend is occurring.
  3. How to True a Bent Bicycle Rim Using Common Tools: adım 3, 2 resimden 1. How to True a Bent Bicycle Rim Using Common Tools: adım 3, 2 resimden 2.
    • Locate the bend by spinning the wheel to see where it doesn't align with the brake.
  4. How to True a Bent Bicycle Rim Using Common Tools: adım 4, 3 resimden 1. How to True a Bent Bicycle Rim Using Common Tools: adım 4, 3 resimden 2. How to True a Bent Bicycle Rim Using Common Tools: adım 4, 3 resimden 3.
    • Locate the two nearest spoke nipples opposite to the bend direction and tighten them a half turn using an adjustable wrench or reaming pliers.
  5. How to True a Bent Bicycle Rim Using Common Tools: adım 5, 2 resimden 1. How to True a Bent Bicycle Rim Using Common Tools: adım 5, 2 resimden 2.
    • Pluck the spoke and listen to the pitch to check its tightness.
    • If the pitch is higher, you are tightening it, and if the pitch is lower, you are loosening it.
  6. How to True a Bent Bicycle Rim Using Common Tools: adım 6, 2 resimden 1. How to True a Bent Bicycle Rim Using Common Tools: adım 6, 2 resimden 2.
    • Loosen the spoke nipples opposite to the ones being tightened to reduce stress in the wrong direction.
  7. How to True a Bent Bicycle Rim Using Common Tools: adım 7, 1 resimden 1.
    • Assess the dent in the bike rim and assure it's mostly straightened out relative to the break pad.
    • Repeat the tightening/loosening process accordingly if necessary.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Charles Tweedy
163 İtibar
1 Kılavuz yazıldı
Ekip
UCD-MORRIS-S23S1G4 UCD-MORRIS-S23S1G4 üyesi
Community
2 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 43
Her zaman: 1,483
