Ana içeriğe geç
How to True a Bicycle Wheel with Zip Ties
Niyoosha Tahami
Niyoosha Tahami ve başka bir katkıda bulunan
En son August 14, 2024 tarihinde güncellendi
5 dakika
Kolay
If your bike is shaking violently when riding at high speeds, odds are that your wheels are not balanced. This can occur from crashes or riding your bike on rough terrain. Luckily, this is a straightforward fix. Balancing your wheels will ensure your bike is safe and in working order.
Before you begin, please ensure your bike is securely placed to avoid injuries.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. How to True a Bicycle Wheel with Zip Ties, How to True a Bicycle Wheel with Zip Ties: adım 1, 1 resimden 1.
    • Place your bike upside down.
  2. How to True a Bicycle Wheel with Zip Ties: adım 2, 1 resimden 1.
    • Tie a zip tie next to the rim of your wheel.
  3. How to True a Bicycle Wheel with Zip Ties: adım 3, 2 resimden 1. How to True a Bicycle Wheel with Zip Ties: adım 3, 2 resimden 2.
    • Cut the zip tie.
    • The zip tie should barely touch the rim.
  4. How to True a Bicycle Wheel with Zip Ties: adım 4, 1 resimden 1.
    • Spin the wheel and mark the spots where the rim touches the zip tie.
  5. How to True a Bicycle Wheel with Zip Ties: adım 5, 2 resimden 1. How to True a Bicycle Wheel with Zip Ties: adım 5, 2 resimden 2.
    • Slowly loosen the spoke that is on the side of the zip tie.
    • Slowly tighten the spoke that is away from the zip tie.
    • Turn clockwise to tighten and counterclockwise to loosen.
  6. How to True a Bicycle Wheel with Zip Ties: adım 6, 1 resimden 1.
    • Repeat steps 2 to 5 with the zip tie on the other side of the wheel.
Sonuç
Repeat the instructions on your other wheel.
Niyoosha Tahami
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 183
