Ana içeriğe geç
How to Unclog an Epson ET-2760 Printhead
Jack Buttry
Jack Buttry ve başka bir katkıda bulunan
En son January 8, 2025 tarihinde güncellendi
30 - 45 dakika
Orta
If your Epson ET-2760 printer is not printing complete lines and is having trouble printing a full color image, use this procedure to manually unclog the printhead.
The printhead supplies and transfers the ink onto the paper into the correct form for whatever is being printed, so before beginning, perform a head cleaning or a power cleaning to make sure that the issue must be dealt with manually. From here, the guide can be started following the steps below.
All of the following steps are easy to perform and require no prior skills. However, there is a chance that ink could get on one’s hands and clothes, so don't wear your favorite shirt!
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. How to Unclog an Epson ET-2760 Printhead, How to Unclog an Epson ET-2760 Printhead: adım 1, 2 resimden 1. How to Unclog an Epson ET-2760 Printhead, How to Unclog an Epson ET-2760 Printhead: adım 1, 2 resimden 2.
    • Begin a print of any kind, or a nozzle check.
    • Once the print has begun, pull the power cable out mid-print.
  2. How to Unclog an Epson ET-2760 Printhead: adım 2, 2 resimden 1. How to Unclog an Epson ET-2760 Printhead: adım 2, 2 resimden 2.
    • Open the printer, then pull out the half-printed paper through the slot.
    • Place a thick paper towel or rag under the printhead.
  3. How to Unclog an Epson ET-2760 Printhead: adım 3, 3 resimden 1. How to Unclog an Epson ET-2760 Printhead: adım 3, 3 resimden 2. How to Unclog an Epson ET-2760 Printhead: adım 3, 3 resimden 3.
    • Remove the single screw with a Phillips #0 screwdriver.
    • Unclip the two white plastic clips.
    • Lift the top cover off of the printhead.
  4. How to Unclog an Epson ET-2760 Printhead: adım 4, 1 resimden 1.
    • Unclip the four ink cartridges from the printhead by pulling the small tabs on top of the cartridges.
    • Be sure not to disconnect the ink lines from the cartridges. Simply set the connected cartridges to the side of the printhead.
  5. How to Unclog an Epson ET-2760 Printhead: adım 5, 2 resimden 1. How to Unclog an Epson ET-2760 Printhead: adım 5, 2 resimden 2.
    • Fill a syringe with printhead cleaning solution and place the syringe tip over the holes left by the cartridges.
  6. How to Unclog an Epson ET-2760 Printhead: adım 6, 1 resimden 1.
    • Begin to flush the manufacturer's recommended amount of solution through each hole onto the paper towel.
    • If necessary, swap out the paper towel in between flushes to prevent any solution from entering the printer.
  7. How to Unclog an Epson ET-2760 Printhead: adım 7, 1 resimden 1.
    • Remove the paper towel from under the printhead.
  8. How to Unclog an Epson ET-2760 Printhead: adım 8, 3 resimden 1. How to Unclog an Epson ET-2760 Printhead: adım 8, 3 resimden 2. How to Unclog an Epson ET-2760 Printhead: adım 8, 3 resimden 3.
    • Reattach each ink cartridge into their original positions.
    • Reattach the two printhead cover clips back onto the printhead.
    • Screw the single screw back into place with a Phillips #0 screwdriver.
  9. How to Unclog an Epson ET-2760 Printhead: adım 9, 1 resimden 1.
    • Perform an automatic cleaning to ensure that any ink residue is removed.
Sonuç
Enjoy your clean printhead!
16 farklı kişi bu kılavuzu tamamladı.
30Kılavuz Yorumları
Simple but to the point tutorial that detailed every step including the tools and supplies needed. Photos helped tremendously too. Thank you.
Mark DiRollo - Yanıt
Where do I find out the "manufacturer's recommended amount of solution" per flush?
Stelios Makrinos - Yanıt
Usually it's 5ml
Casper Hon -
But it seems that ink isn't even getting to my yellow and blue heads. At least, the test print shows no yellow or blue at all.
How can I get at the exit (valves?) on the ink storage tanks to make sure they're clear -- without breaking the printer?
Thanks!
warble58 - Yanıt
Me too! No yellow or blue coming through.
Tracy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 32
Son 7 gün: 241
Son 30 gün: 1,335
Her zaman: 79,613
