Ana içeriğe geç
How to Use Suction Tape
    1. How to Use Suction Tape, Choose the tape: adım 1, 2 resimden 1. How to Use Suction Tape, Choose the tape: adım 1, 2 resimden 2.
      • If you want to secure one side of your two-panel device, skip to this step.
      • If you want to buffer a difficult surface on your device, move to the next step.
      FixBot'a Sor
      Yorum Ekle
    2. How to Use Suction Tape, Measure the tape: adım 2, 3 resimden 1. How to Use Suction Tape, Measure the tape: adım 2, 3 resimden 2. How to Use Suction Tape, Measure the tape: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      Clampy - Anti-Clamp
      $24.95
      • Measure the length of tape you want and mark it with a pen. Consider the following:
      • You need enough tape for the Anti-Clamp's suction cups. Don't leave gaps, or the cups won't stick.
      • Don't use too much tape so it folds over your phone's edges. This may interfere with the opening procedure.
      FixBot'a Sor
      Yorum Ekle
    3. How to Use Suction Tape, Cut the tape: adım 3, 3 resimden 1. How to Use Suction Tape, Cut the tape: adım 3, 3 resimden 2. How to Use Suction Tape, Cut the tape: adım 3, 3 resimden 3.
      • Use scissors to cut the tape to the desired length.
      • Repeat the measuring and cutting procedure for each piece of tape required.
      FixBot'a Sor
      Yorum Ekle
    4. How to Use Suction Tape, Peel the tape: adım 4, 2 resimden 1. How to Use Suction Tape, Peel the tape: adım 4, 2 resimden 2.
      • Peel the tape off its plastic liner.
      FixBot'a Sor
      Yorum Ekle
    5. How to Use Suction Tape, Apply the tape: adım 5, 3 resimden 1. How to Use Suction Tape, Apply the tape: adım 5, 3 resimden 2. How to Use Suction Tape, Apply the tape: adım 5, 3 resimden 3.
      • Apply the tape to the panel of your device where you'll attach the Anti-Clamp.
      FixBot'a Sor
      Yorum Ekle
    6. How to Use Suction Tape, Secure the tape: adım 6, 3 resimden 1. How to Use Suction Tape, Secure the tape: adım 6, 3 resimden 2. How to Use Suction Tape, Secure the tape: adım 6, 3 resimden 3.
      • Use the flat end of a spudger, or your finger, to completely secure the tape to your device.
      • Use a spudger to press out any large bubbles.
      FixBot'a Sor
      Yorum Ekle
    7. How to Use Suction Tape, Open the device: adım 7, 2 resimden 1. How to Use Suction Tape, Open the device: adım 7, 2 resimden 2.
      • Repeat the tape measuring, cutting, and applying process for the opposite side of your device.
      • You're now ready to open your device!
      • Follow this guide for general instructions on how to use the Anti-Clamp.
      FixBot'a Sor
      Yorum Ekle
    8. How to Use Suction Tape, Measure the tape: adım 8, 3 resimden 1. How to Use Suction Tape, Measure the tape: adım 8, 3 resimden 2. How to Use Suction Tape, Measure the tape: adım 8, 3 resimden 3.
      • The remaining steps show how to secure one side of your two-panel device.
      • Choose which panel of the device you don't want to open, and the following steps will show how to secure it.
      • In this example, we want to open the screen, so we'll secure the blue back cover.
      • You need to leave room for the Anti-Clamp's suction cups—don't place tape under them, or they won't stick.
      • Use enough tape to ensure a good hold on the panel you don't want to open.
      • Don't cover the power button with tape, or you might accidentally turn on the device.
      FixBot'a Sor
      Yorum Ekle
    9. How to Use Suction Tape, Peel the tape: adım 9, 2 resimden 1. How to Use Suction Tape, Peel the tape: adım 9, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
    10. How to Use Suction Tape, Cut the tape: adım 10, 2 resimden 1. How to Use Suction Tape, Cut the tape: adım 10, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
    11. How to Use Suction Tape, Apply the tape: adım 11, 3 resimden 1. How to Use Suction Tape, Apply the tape: adım 11, 3 resimden 2. How to Use Suction Tape, Apply the tape: adım 11, 3 resimden 3.
      • Apply the tape to the edges of your device nearest to where you'll attach the Anti-Clamp.
      • Don't fold the tape over the panel you want to open, as this might hinder the opening procedure.
      FixBot'a Sor
      Yorum Ekle
    12. How to Use Suction Tape, Fold the tape: adım 12, 3 resimden 1. How to Use Suction Tape, Fold the tape: adım 12, 3 resimden 2. How to Use Suction Tape, Fold the tape: adım 12, 3 resimden 3.
      • Fold the tape onto the panel you don't want to open.
      • Use your fingers to press down the tape and firmly secure it to your device.
      FixBot'a Sor
      Yorum Ekle
    13. How to Use Suction Tape, Open the device: adım 13, 2 resimden 1. How to Use Suction Tape, Open the device: adım 13, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
Sonuç
For other general electronics skills guides, click here.
7 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
246.383 İtibar
1.203 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
42.765 adet Kılavuz yazıldı
3Kılavuz Yorumları
Does anybody know the brand/type of tape? Searching for "suction tape" online leads to a different product.
Arturo - Yanıt Paylaş
I suggest "carpet tape", used to join carpet sections together and often used for temporary joins in wood and metal working setups; or maybe Gorilla brand gaffer tape which is very grippy and has lots of reinforceing fiber strands for low stretch, (useing it now to hold the hinges of a laptop together till I get it fixed properly). Both can be found in most hardware/home care stores in USA. Cleanup of adhesive residue maybe a pain, requireing "goo gone" or WD-40 followed by alcohol wipes.
Kevin Smith - Yanıt Paylaş
I would like to check the material of this product. Anyone can help me?
Nguyễn Thị Vân Anh - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 77
Son 30 gün: 340
Her zaman: 12,117
