Ana içeriğe geç
How to Use the VoltClip to Debond iPhone Battery Adhesive
Arthur Shi
Arthur Shi ve 2 diğer katkıda bulunanlar
En son April 4, 2025 tarihinde güncellendi
2 - 10 dakika
Orta
This guide demonstrates how to use iFixit's VoltClip to loosen adhesives that use the "electrical debonding-on-demand" technology. iPhone 16 and 16 Plus batteries use this type of adhesive.
Electrical debonding-on-demand works by passing low electrical current through the adhesive. A 9–30 volt DC source is connected across the adhesive, and the resulting electrochemical reaction loosens the adhesive bond in minutes.
The VoltClip requires a USB-C Power Delivery (PD) power source. This can either be the FixHub Portable Power Station, a USB-C PD power brick, or some laptops/smartphones. Not all USB-C PD power sources support 12 V (the FixHub Portable Power Station does). If the source doesn't support 12 V, the VoltClip will operate at the next lowest voltage—usually 9 V. This voltage is still sufficient to debond the adhesive—it just takes longer.
This guide was written using an iPhone 16. For complete iPhone battery replacement instructions, click here and find your specific device's repair manual.
  1. How to Use the VoltClip to Debond iPhone Battery Adhesive, Assemble the VoltClip: adım 1, 2 resimden 1. How to Use the VoltClip to Debond iPhone Battery Adhesive, Assemble the VoltClip: adım 1, 2 resimden 2.
    • Plug the VoltClip's barrel connector into the USB-C elbow.
    • Don't connect the VoltClip to a power source just yet. The loose alligator clips may accidentally touch each other and cause an electrical short.
  2. How to Use the VoltClip to Debond iPhone Battery Adhesive, Peel up the silver tab: adım 2, 2 resimden 1. How to Use the VoltClip to Debond iPhone Battery Adhesive, Peel up the silver tab: adım 2, 2 resimden 2.
    • Use a clean fingernail or an opening pick to peel up the silver tab at the bottom edge of the battery.
  3. How to Use the VoltClip to Debond iPhone Battery Adhesive, Attach the alligator clips: adım 3, 2 resimden 1. How to Use the VoltClip to Debond iPhone Battery Adhesive, Attach the alligator clips: adım 3, 2 resimden 2.
    • Attach the red alligator clip to the silver tab on the battery.
  4. How to Use the VoltClip to Debond iPhone Battery Adhesive: adım 4, 3 resimden 1. How to Use the VoltClip to Debond iPhone Battery Adhesive: adım 4, 3 resimden 2. How to Use the VoltClip to Debond iPhone Battery Adhesive: adım 4, 3 resimden 3.
    • Attach the black alligator clip to the grounding screw.
  5. How to Use the VoltClip to Debond iPhone Battery Adhesive, Connect power to the VoltClip: adım 5, 3 resimden 1. How to Use the VoltClip to Debond iPhone Battery Adhesive, Connect power to the VoltClip: adım 5, 3 resimden 2. How to Use the VoltClip to Debond iPhone Battery Adhesive, Connect power to the VoltClip: adım 5, 3 resimden 3.
    • Make sure the red alligator clip isn't touching any stray metallic surfaces.
    • Connect a powered USB-C cable to the USB-C elbow and wait 90 seconds for the adhesive to loosen.
  6. How to Use the VoltClip to Debond iPhone Battery Adhesive, Disconnect the VoltClip: adım 6, 3 resimden 1. How to Use the VoltClip to Debond iPhone Battery Adhesive, Disconnect the VoltClip: adım 6, 3 resimden 2. How to Use the VoltClip to Debond iPhone Battery Adhesive, Disconnect the VoltClip: adım 6, 3 resimden 3.
    • Disconnect the USB-C cable from the elbow, then disconnect the alligator clips.
  7. How to Use the VoltClip to Debond iPhone Battery Adhesive, Remove the battery: adım 7, 3 resimden 1. How to Use the VoltClip to Debond iPhone Battery Adhesive, Remove the battery: adım 7, 3 resimden 2. How to Use the VoltClip to Debond iPhone Battery Adhesive, Remove the battery: adım 7, 3 resimden 3.
    • Your adhesive should be fully loosened at this point. If your battery doesn't budge during the step, reconnect the VoltClip for an additional minute and try again.
    • Grip the silver tab and lift the battery out of the frame.
    • Alternatively, you can use a suction handle to pull the battery out. If the battery doesn't come out easily, don't force it—reconnect the VoltClip for one minute.
Sonuç
For more iPhone guides, click here.
3 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
284.401 İtibar
588 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.806 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 66
Son 30 gün: 327
Her zaman: 7,272
