Ana içeriğe geç
How to align Razor A steering
Neye ihtiyacın var
  1. How to align Razor A steering, How to align Razor A steering: adım 1, 3 resimden 1. How to align Razor A steering, How to align Razor A steering: adım 1, 3 resimden 2. How to align Razor A steering, How to align Razor A steering: adım 1, 3 resimden 3.
    • Locate the collar clamp near the base of the steering column.
    • Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
    • The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
    at this part it would easily loosen for a few seconds then get hard again can you update this and mention that please if its normal
    Caleb Rigby (Awesomegamez) - Yanıt
    After loosening and re-aligning make sure to tighten it back up really tight so the problem will be avoided for a while. Eventually you will probably have to do this again after using the scooter a lot.
    Nolan Proulx - Yanıt
  2. How to align Razor A steering: adım 2, 2 resimden 1. How to align Razor A steering: adım 2, 2 resimden 2.
    • Firmly grasp the steering column and turn the wheel by hand.
    • View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
    • The second picture above shows a correct alignment of the steering column from this view.
Bitiş Çizgisi
17 farklı kişi bu kılavuzu tamamladı.
Jordyn
565 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G13
4 Üyeler
10 adet Kılavuz yazıldı
4Kılavuz Yorumları
This is so unhelpful.
Linh Tran - Yanıt
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Max Kittens - Yanıt
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
Kathy Earhart - Yanıt
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
Alan Weinberg - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 20
Son 30 gün: 54
Her zaman: 30,685
