Ana içeriğe geç
How to convert your Mac's storage from HFS to APFS file system
    • As a preventative measure, it is highly recommended you create an external backup drive to backup your files to
    • Typically converting your file system should not effect your data, but there is always a risk of loosing data when messing with the internal drive.
    FixBot'a Sor
    Yorum Ekle
  1. How to convert your Mac's storage from HFS to APFS file system, Open Disk Utility and click on the View option: adım 2, 2 resimden 1. How to convert your Mac's storage from HFS to APFS file system, Open Disk Utility and click on the View option: adım 2, 2 resimden 2.
    • Open the Disk Utility application and click the View option in the left hand corner.
    • From the drop down menu, choose the Show All Devices option from the list.
    FixBot'a Sor
    Yorum Ekle
  2. How to convert your Mac's storage from HFS to APFS file system, Select the drive you want to convert: adım 3, 1 resimden 1.
    • You should see a list of all your containing drives within each of their respective volume. Select the drive you want to convert and click the Partition button from the buttons in the upper right hand side of the window.
    FixBot'a Sor
    Yorum Ekle
    • Make sure your Scheme is set to GUID Partition Map
    • Depending on the drive you're converting, your Scheme may be set to the "MS-DOS" format. In this case you would need to change the partition format.
    FixBot'a Sor
    Yorum Ekle
    • Select Mac OS Extended (Journaled) from the "Format" dropdown menu.
    • Make sure the settings are correct, and click the Apply button.
    FixBot'a Sor
    Yorum Ekle
    • Right click on the partition you set, and select Convert to APFS.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Congratulations! You have successfully converted your drive to APFS. As stated previously, your files should have not been touched, always make sure everything is correct.
4 farklı kişi bu kılavuzu tamamladı.
Jacob Mehnert
49.106 İtibar
51 adet Kılavuz yazıldı
Ekip
iFanatics iFanatics üyesi
Community
69 Üyeler
237 adet Kılavuz yazıldı
1Rehber Yorum
Above, it says under “Cons of APFS” that it “Does not support Fusion drives.” This is incorrect. My 2019 iMac runs Sonoma and has automatically converted my Fusion drive to APFS, dramatically slowing down the system. Don’t convert or permit APFS file systems on mechanical or “fusion” (hybrid) type hard drives, unless you really want to torture yourself and your Mac!
reeskm - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 185
Son 30 gün: 456
Her zaman: 29,421
