Ana içeriğe geç
How to determine Mac shutdown causes
  1. How to determine Mac shutdown causes, Open Terminal.app: adım 1, 1 resimden 1.
    • Open Terminal.app
  2. How to determine Mac shutdown causes, Listing previous shutdowns: adım 2, 1 resimden 1.
    • Copy and paste the following command in your Terminal window:
    • log show --predicate 'eventMessage contains "Previous shutdown cause"' --last 24h
    • The "24h" portion of the command can be changed to any number of hours, depending on how far back you need to see.
  3. How to determine Mac shutdown causes, Determining Shutdown Causes: adım 3, 1 resimden 1.
    • The previous shutdown causes in the timeframe you selected will appear as a list.
    • Common shutdown causes include 5 which indicates a normal shutdown, 3 which indicates a hard shutdown (i.e. holding the power button), and 0 which indicates the power was disconnected.
    • A list of shutdown causes can be found here: Shutdown causes (from George Garside blog)
Sonuç
Done! You should be able to use these codes to further troubleshoot random shutdowns or other strange events.
Hit the button below if this guide helped solve your issue :)
24 farklı kişi bu kılavuzu tamamladı.
Ekli Belgeler
Jonah Aragon
5.699 İtibar
5 adet Kılavuz yazıldı
Ekip
Experimax Coon Rapids Experimax Coon Rapids üyesi
Business
3 Üyeler
19 adet Kılavuz yazıldı
14Kılavuz Yorumları
For me it says
kernel: (AppleSMC) Previous shutdown cause: -20
The attached PDF (and the internet) doesn’t seem to have any information about this code. What’s the source of the codes for the PDF? Maybe they have updated listing for shutdown codes.
Saurabh Shrivastava - Yanıt
we also have -20 as a cause and have no idea what it means. did you ever find it out?
octomobiki -
I also have -20 code of shut down after macOS 10.15.5 update with MBP 16inches model.
but no information at all….
赤月小黄泉 -
writErr = -20, /*I/O System Errors*/ its this error for code -20 .. Find all error codes here :- https://krypted.com/lists/comprehensive-...
UNKNOWN X -
Sorry , that was not related, check this one : - https://georgegarside.com/blog/macos/shu...
and, error code 20- T2 security chip initiated shutdown
UNKNOWN X -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 108
Son 30 gün: 550
Her zaman: 104,038
