Ana içeriğe geç
How to open the iPhone SE 2022 for repairs
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. How to open the iPhone SE 2022 for repairs, Remove the pentalobe screws: adım 1, 2 resimden 1. How to open the iPhone SE 2022 for repairs, Remove the pentalobe screws: adım 1, 2 resimden 2.
    • Power off your phone before beginning disassembly.
    • Remove the two 3.4 mm P2 pentalobe screws on the bottom edge of the iPhone.
  2. How to open the iPhone SE 2022 for repairs, Tape over any cracks: adım 2, 3 resimden 1. How to open the iPhone SE 2022 for repairs, Tape over any cracks: adım 2, 3 resimden 2. How to open the iPhone SE 2022 for repairs, Tape over any cracks: adım 2, 3 resimden 3.
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  3. How to open the iPhone SE 2022 for repairs, Anti-Clamp instructions: adım 3, 3 resimden 1. How to open the iPhone SE 2022 for repairs, Anti-Clamp instructions: adım 3, 3 resimden 2. How to open the iPhone SE 2022 for repairs, Anti-Clamp instructions: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. How to open the iPhone SE 2022 for repairs: adım 4, 3 resimden 1. How to open the iPhone SE 2022 for repairs: adım 4, 3 resimden 2. How to open the iPhone SE 2022 for repairs: adım 4, 3 resimden 3.
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. How to open the iPhone SE 2022 for repairs: adım 5, 3 resimden 1. How to open the iPhone SE 2022 for repairs: adım 5, 3 resimden 2. How to open the iPhone SE 2022 for repairs: adım 5, 3 resimden 3.
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. How to open the iPhone SE 2022 for repairs, Heat the front panel adhesive: adım 6, 1 resimden 1.
    • If you're using a suction handle, follow the next two steps to loosen the rear glass.
    • Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  7. How to open the iPhone SE 2022 for repairs, Insert an opening pick: adım 7, 3 resimden 1. How to open the iPhone SE 2022 for repairs, Insert an opening pick: adım 7, 3 resimden 2. How to open the iPhone SE 2022 for repairs, Insert an opening pick: adım 7, 3 resimden 3.
    • Secure a suction handle to the lower half of the front panel, as close to the home button as possible.
    • Lift the front panel with the suction handle to create a small gap between the front panel and the frame.
    • If you have trouble creating a gap, apply more heat to the bottom half of the screen to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap under the screen's plastic bezel.
  8. How to open the iPhone SE 2022 for repairs, Slice the adhesive: adım 8, 3 resimden 1. How to open the iPhone SE 2022 for repairs, Slice the adhesive: adım 8, 3 resimden 2. How to open the iPhone SE 2022 for repairs, Slice the adhesive: adım 8, 3 resimden 3.
    • Slide the opening pick to the bottom right corner to slice the front panel adhesive.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  9. How to open the iPhone SE 2022 for repairs, Slice the adhesive: adım 9, 3 resimden 1. How to open the iPhone SE 2022 for repairs, Slice the adhesive: adım 9, 3 resimden 2. How to open the iPhone SE 2022 for repairs, Slice the adhesive: adım 9, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Slide the bottom left opening pick along the left edge of your phone to slice the adhesive.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  10. How to open the iPhone SE 2022 for repairs: adım 10, 3 resimden 1. How to open the iPhone SE 2022 for repairs: adım 10, 3 resimden 2. How to open the iPhone SE 2022 for repairs: adım 10, 3 resimden 3.
    • Slide the bottom right opening pick along the right edge of your phone to slice the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Stop near the top right corner of the display.
  11. How to open the iPhone SE 2022 for repairs, Lift the screen: adım 11, 2 resimden 1. How to open the iPhone SE 2022 for repairs, Lift the screen: adım 11, 2 resimden 2.
    • Remove the opening picks.
    • Gently pull up on the suction handle to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Remove the suction handle.
  12. How to open the iPhone SE 2022 for repairs, Slice the remaining adhesive: adım 12, 3 resimden 1. How to open the iPhone SE 2022 for repairs, Slice the remaining adhesive: adım 12, 3 resimden 2. How to open the iPhone SE 2022 for repairs, Slice the remaining adhesive: adım 12, 3 resimden 3.
    • Slide an opening pick underneath the top left corner of the display.
    • Slide the opening pick around the top left corner and along the top edge of the phone to slice the remaining adhesive.
  13. How to open the iPhone SE 2022 for repairs, Disengage the front panel clips: adım 13, 2 resimden 1. How to open the iPhone SE 2022 for repairs, Disengage the front panel clips: adım 13, 2 resimden 2.
    • Slide the display assembly slightly down in direction of the charging port to disengage the clips holding it to the rear case.
  14. How to open the iPhone SE 2022 for repairs, Lift up the display: adım 14, 3 resimden 1. How to open the iPhone SE 2022 for repairs, Lift up the display: adım 14, 3 resimden 2. How to open the iPhone SE 2022 for repairs, Lift up the display: adım 14, 3 resimden 3.
    • Open the phone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display from the phone assembly yet, as several fragile ribbon cables still connect it to the logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
Sonuç
Dominik Schnabelrauch
228.990 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.418 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 87
