Ana içeriğe geç
How to repair Touch ID in an iPhone SE
Alex Sander
Alex Sander ve 3 diğer katkıda bulunanlar
En son August 22, 2022 tarihinde güncellendi
10 - 20 dakika
Zor
Topluluk-Katkılı Kılavuz
Transkripsiyon gerekiyor
Neye ihtiyacın var
    • In this tutorial you will find out how to fix not working touch ID in an Apple iPhone SE. If you need further assistance ask questions in the comments.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alex Sander
38.930 İtibar
201 adet Kılavuz yazıldı
4Kılavuz Yorumları
No explanations at all? What’s the yellow film? Is that a heated surface or a heat gun off camera?
Mike Moran - Yanıt
The yellow stuff is presumably Kapton (heat-resistant) tape, and it looks like there’s a heat gun off to the right. I’ve never seen Kapton tape used like this—my guess is that the technician is attempting to blow hot air between the connector and the flex without melting the plastic on either. But if the hot air is correctly applied (which takes practice), the heat will go to the metal and solder and not the plastic, and the plastic won’t melt.
One other comment: unless the SE is different, it’s an understatement to say “you don’t need to use a new home button.” If you DO use a new home button, fingerprint sensing won’t work. It relies on hardware that is underneath the home button itself, and is paired to the motherboard (the CPU, I think). If you can splice flex cables, you can cut the home button away from its original flex and splice it on to a new flex, retaining fingerprint sensing (at least I’ve seen this done on YouTube). Otherwise I think you’re out of luck.
Bonnie Baxter - Yanıt
what is liquid ?
Rahim Araz - Yanıt
That’s a lousy clip, or at least, not helpful for anyone who never did microscopic soldering before. At any rate, the “guide” is focusing on just showing the soldering part - but no background whatsoever. Show how the part looks before and after - how that thingy is related to the home-button at all —- something! you can’t expect anyone to use this movie, I think
Motti Shneor - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 59
Her zaman: 10,186
