Ana içeriğe geç
How to repair a hole in a crochet dishcloth
Neye ihtiyacın var
  1. How to repair a hole in a crochet dishcloth, How to repair a hole in a crochet dishcloth: adım 1, 1 resimden 1.
    • Collect the tools and materials you'll need.
  2. How to repair a hole in a crochet dishcloth: adım 2, 3 resimden 1. How to repair a hole in a crochet dishcloth: adım 2, 3 resimden 2. How to repair a hole in a crochet dishcloth: adım 2, 3 resimden 3.
    • Identify any loose loops that may come undone if any yarn is pulled.
    • Put a safety pin through the loops, this will prevent the hole from getting any bigger.
  3. How to repair a hole in a crochet dishcloth: adım 3, 3 resimden 1. How to repair a hole in a crochet dishcloth: adım 3, 3 resimden 2. How to repair a hole in a crochet dishcloth: adım 3, 3 resimden 3.
    • Pick one of the loose strands and tie the yarn to this strand.
    • Make three knots to ensure the knot will not come undone.
  4. How to repair a hole in a crochet dishcloth: adım 4, 3 resimden 1. How to repair a hole in a crochet dishcloth: adım 4, 3 resimden 2. How to repair a hole in a crochet dishcloth: adım 4, 3 resimden 3.
    • Begin your first stitch by pushing the crochet hook through the stitch closest to the tied on yarn.
    • Next, wrap the yarn in front of the hook and pull it through the stitch making sure the hook catches the yarn.
  5. How to repair a hole in a crochet dishcloth: adım 5, 3 resimden 1. How to repair a hole in a crochet dishcloth: adım 5, 3 resimden 2. How to repair a hole in a crochet dishcloth: adım 5, 3 resimden 3.
    • Continuing on your first stitch, wrap the yarn in front of the hook and pull it in the direction of the arrow through the loop wrapped around the crochet hook.
    • Move on to the next stitch where the orange arrow is pointing. Continue making stitches around the hole until there is a small opening.
  6. How to repair a hole in a crochet dishcloth: adım 6, 3 resimden 1. How to repair a hole in a crochet dishcloth: adım 6, 3 resimden 2. How to repair a hole in a crochet dishcloth: adım 6, 3 resimden 3.
    • Once you have a small opening you will now close the hole. Using the same stitch used throughout the guide, make a stitch interlocking every other stitch.
    • The crochet hook should be moving in the direction the arrow is pointing.
  7. How to repair a hole in a crochet dishcloth: adım 7, 3 resimden 1. How to repair a hole in a crochet dishcloth: adım 7, 3 resimden 2. How to repair a hole in a crochet dishcloth: adım 7, 3 resimden 3.
    • Continuing until the hole is completely closed.
    • Cut the yarn leaving about a 4 inch tail.
    • Pull the loop in the direction the arrow is pointing.
  8. How to repair a hole in a crochet dishcloth: adım 8, 3 resimden 1. How to repair a hole in a crochet dishcloth: adım 8, 3 resimden 2. How to repair a hole in a crochet dishcloth: adım 8, 3 resimden 3.
    • Using the large threading needle, thread in all of the strands of yarn.
Sonuç
Rayme Ivers
157 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G8, Cardinal Spring 2020 UW Tacoma, Team S1-G8, Cardinal Spring 2020 üyesi
UWT-CARDINAL-S20S1G8
1 Üye
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 50
Her zaman: 3,543
