Ana içeriğe geç
How to repair the Eurolite N-19 Fog Machine
Neye ihtiyacın var
  1. How to repair the Eurolite N-19 Fog Machine, Opening the fog machine: adım 1, 1 resimden 1.
    • Open the fog machine by removing the screws on the sides of the fog machine with the appropriate screwdriver.
    • Remove the outer casing of the fog machine.
  2. How to repair the Eurolite N-19 Fog Machine, Evaluating the problem: adım 2, 1 resimden 1.
    • If the fog machine does not heat up, a fuse or another heating element could be malfunctioning.
    • If no smoke is coming out of the fog machine, then the pump could be malfunctioning
    Link is spam. (As you may have guessed after reading this far, the author isn't actually trying to help you fix your machine.) Don't click the link to the guide.
    Daniel Jackson - Yanıt
  3. How to repair the Eurolite N-19 Fog Machine, Repairing the fog machine: adım 3, 1 resimden 1.
    • In this instance, all that was needed was a new heat fuse and new spade connectors
    • In this case, I needed to remove the heat fuse and the spade connectors then needed to connect the new heat fuse and spade connectors to their respective locations
    • The heat fuse sits under the bimetal. (Cannot be seen clearly in the picture)
    Is heat fuse has on ampere rating? for a 900W fog machine what will be the rating of the heat fuse?
    Julio Pelino - Yanıt
    If you divide the power in Watts by the connection voltage in Volts, you get the current consumption in Amperes.
    For example: 900 Watt divided by 230 Volt gives 3.9 Amperes.
    The thermal fuse will probably be printed with voltage and/or current values.
    Toon Konings - Yanıt
  4. How to repair the Eurolite N-19 Fog Machine, Reassembling the fog machine: adım 4, 1 resimden 1.
    • To reassemble your machine, follow the steps for diassembly in reverse order.
    Where did you find the parts? (Heat fuse)
    Todd Maxwell - Yanıt
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
rjay
233 İtibar
1 Kılavuz yazıldı
23 Yorum
My fogger heater is jam how can I clean it?
vishal_kishor777 - Yanıt
hmm… I think I could have written a better guide myself. Okay so I have a 3 pin XLR for phase does anyone know how this works also I noted that the fuse was melted into its holster and the pump seems dead. My Fogger also has some kind of potentiometer which controls the heating element which is like a ceramic sandwich and two spark plugs… I also was wondering if glycerin fog juice can be made with vegetable glycerin or the glycol type or if this is what cloggs the machine. Also will clr work or be dangerous fume wise? Can you market glycerine as fog juice thickener like STP fuel additives for cars?? g0pg.xyz is my website you can learn how to force push graphite if you look for the post with yoda!
Ember Leona - Yanıt
Where can I buy a fuse like this? Have looked over the net, but could not find any shops that would sell CH-15 fuse, used in this fog machine. If anyone knows about this, please share info. Thanks! By the way, I’m based in EU.
Giedrius Stasiulis - Yanıt
I would make a post on Halloweenform.com
Mad_as_a_hatter -
My fog machine is not pumping out smoke
Ohwaga Kerry - Yanıt
Have you cleaned your machine?
Mad_as_a_hatter -
No power to my fog machine ?
David McCartie - Yanıt
Thw machine doesn't power on at all? Dose it get hot ? If it not getting hot. Check the fuse. If you hear the pump trying to work and nothing comes out. You would need to use fog cleaner or water and white vinegar.
Mad_as_a_hatter -
My FM400-1 fog machine pumps out fog for 1 minute then stops, cools and then pumps out fog for another minute then stops again. Is this normal or is the safety device wearing out?
Paul Houle - Yanıt
Yeah that would be normal for a 400 watt fog machine. The heating element has to be 200 to 250 degrees. When pumping fog it will cool it down. The heating element needs to reheat up again. Before it will pump more fog.
Mad_as_a_hatter -
My fumigation machine is not fuming out smoke
MANMEET KHALSA - Yanıt
Have you cleaned your machine? You can fog cleaner or you can use water and white vinegar.
Mad_as_a_hatter -
Can we use 900W coil instead of 1500W coil in a machine
Rajendra Katote - Yanıt
Just guessing I would say not. Depends on the model and the watts you would want to find a similar replacement. You could even find a broken fog machine to use as parts
Mad_as_a_hatter -
Heating fuse was hidden why didn’t you take a photo of it since you replaced it. This is the only info I could find and it’s incomplete! Im going to a corner to cry now
traceelauren - Yanıt
Hallo,
bei meiner N-19 musste die defekte Pumpe getauscht werden. Leider habe ich es versäumt mir zu notieren wohin die beiden Kabel der Pumpe angeschlossen werden. Wer kann mir helfen und es mir erklären ? ?
HajoPianoMan - Yanıt
I am not sure that what is being replaced is a heat fuse. It rather looks like a temperature switch. The difference is that the temperature switch is supposed to work on a regular basis, while the fuse can usually not be reset and just breaks in case of overheat. I entirely dismantled such a machine and it does not seem to contain an heat fuse. Lack of actual heat fuse might be a security issue, because the temperature switch may fail (I have no knowledge of “failure modes” of theses switches, but notes that in coffee machines, it is common to have both a thermostat (acting as the temperature switch here) and a heat fuse (which would activate if the switch fails and temperature reaches levels beyond which it could be dangerous). Conclusion : always keep an eye on these potentially unsafe machines.
pmarbaix - Yanıt
No power 2 mg fog machine, no heat no Pump I have an s2500 beamz or a 1700w its a stage fog machine help me please
Mel - Yanıt
I have a second hand beams s500 that only works for about 10 seconds then cuts out then 10 seconds again when it green lights again and so on. I'm assuming there is a fault. Any ideas please?
mcpeorange - Yanıt
Dobrý den, mám dotaz, vlastním výrobník mlhy eurolite N19 . Momentálně byl dva roky mimo provoz,koupil sem čistící roztok, vyčistil a profoukl i kompresorem, vše funguje, topné tělísko hřeje, čerpadlo pracuje,ale mlha se vytlačí pouze třeba jen na 6-7 sepnutí a pak třeba další dvě hodiny nereaguje myslíte,že je chyba v čerpadle nebo stále někde zanesena tryska?
lukasvrastil - Yanıt
Is er een stroomkringschema beschikbaar?
Christiaan Klompstra - Yanıt
Anyone have a source/link on inexpensive replacement heater blocks? The cheapest ones I found were on Aliexpress & they were around $50
Micah Woloschuk - Yanıt
My fog machine is not pushing out any fog just liquid is spraying out
avinash ramkissoon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 59
Son 30 gün: 207
Her zaman: 63,673
