Ana içeriğe geç
Huawei M750 Charging Port Replacement
Neye ihtiyacın var
  1. Huawei M750 Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Huawei M750 Charging Port Replacement: adım 2, 1 resimden 1.
    • Remove the battery by levering the battery out, using the cut just below the camera.
    FixBot'a Sor
    Yorum Ekle
  3. Huawei M750 Charging Port Replacement, Back Panel: adım 3, 1 resimden 1.
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
    FixBot'a Sor
    Yorum Ekle
  4. Huawei M750 Charging Port Replacement: adım 4, 2 resimden 1. Huawei M750 Charging Port Replacement: adım 4, 2 resimden 2.
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
    FixBot'a Sor
    Yorum Ekle
  5. Huawei M750 Charging Port Replacement: adım 5, 2 resimden 1. Huawei M750 Charging Port Replacement: adım 5, 2 resimden 2.
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
    FixBot'a Sor
    Yorum Ekle
  6. Huawei M750 Charging Port Replacement, Charging Port: adım 6, 2 resimden 1. Huawei M750 Charging Port Replacement, Charging Port: adım 6, 2 resimden 2.
    • Using the opening tool, start prying out the motherboard from the front panel along the border.
    • When the motherboard seems separated from the front panel, pull it outwards.
    FixBot'a Sor
    Yorum Ekle
  7. Huawei M750 Charging Port Replacement: adım 7, 2 resimden 1. Huawei M750 Charging Port Replacement: adım 7, 2 resimden 2.
    • The charging port is soldered to the motherboard, use this guide to do the replacement.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 35
Her zaman: 576
