Ana içeriğe geç
Huawei M750 Charging Port Replacement
Neye ihtiyacın var
  1. Huawei M750 Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
  2. Huawei M750 Charging Port Replacement: adım 2, 1 resimden 1.
    • Remove the battery by levering the battery out, using the cut just below the camera.
  3. Huawei M750 Charging Port Replacement, Back Panel: adım 3, 1 resimden 1.
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
  4. Huawei M750 Charging Port Replacement: adım 4, 2 resimden 1. Huawei M750 Charging Port Replacement: adım 4, 2 resimden 2.
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
  5. Huawei M750 Charging Port Replacement: adım 5, 2 resimden 1. Huawei M750 Charging Port Replacement: adım 5, 2 resimden 2.
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
  6. Huawei M750 Charging Port Replacement, Charging Port: adım 6, 2 resimden 1. Huawei M750 Charging Port Replacement, Charging Port: adım 6, 2 resimden 2.
    • Using the opening tool, start prying out the motherboard from the front panel along the border.
    • When the motherboard seems separated from the front panel, pull it outwards.
  7. Huawei M750 Charging Port Replacement: adım 7, 2 resimden 1. Huawei M750 Charging Port Replacement: adım 7, 2 resimden 2.
    • The charging port is soldered to the motherboard, use this guide to do the replacement.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 250
