Ana içeriğe geç
Huawei Mate 10 Pro Battery Replacement
Neye ihtiyacın var
  1. Huawei Mate 10 Pro Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Switch off your phone.
    • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
  2. Huawei Mate 10 Pro Battery Replacement: adım 2, 3 resimden 1. Huawei Mate 10 Pro Battery Replacement: adım 2, 3 resimden 2. Huawei Mate 10 Pro Battery Replacement: adım 2, 3 resimden 3.
    • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
    • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
    • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
  3. Huawei Mate 10 Pro Battery Replacement: adım 3, 2 resimden 1. Huawei Mate 10 Pro Battery Replacement: adım 3, 2 resimden 2.
    • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
    • Flip the back cover over to the side.
    • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
  4. Huawei Mate 10 Pro Battery Replacement: adım 4, 2 resimden 1. Huawei Mate 10 Pro Battery Replacement: adım 4, 2 resimden 2.
    • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
    • Disconnect the fingerprint sensor cable with a spudger.
    • When reassembling your phone apply new adhesive where it is necessary.
  5. Huawei Mate 10 Pro Battery Replacement, Shields: adım 5, 3 resimden 1. Huawei Mate 10 Pro Battery Replacement, Shields: adım 5, 3 resimden 2. Huawei Mate 10 Pro Battery Replacement, Shields: adım 5, 3 resimden 3.
    • Remove the twelve Phillips #00 screws.
    • Carefully remove the shields on top of the motherboard and the charging board.
    • In case the shields do not pop out easily on their own after you removed the Phillips screws, you can use the pointed end of a spudger to pry them out.
  6. Huawei Mate 10 Pro Battery Replacement, Charging Port: adım 6, 2 resimden 1. Huawei Mate 10 Pro Battery Replacement, Charging Port: adım 6, 2 resimden 2.
    • Use a spudger to disconnect the charging port flex cable from the motherboard and from the daughterboard.
  7. Huawei Mate 10 Pro Battery Replacement: adım 7, 2 resimden 1. Huawei Mate 10 Pro Battery Replacement: adım 7, 2 resimden 2.
    • Use a pair of tweezers to carefully remove the charging port including its flex cable.
    • The charging port sits tightly in its recess. In case you have trouble removing it, use the flat end of a halberd spudger to pry it out.
  8. Huawei Mate 10 Pro Battery Replacement, Battery: adım 8, 2 resimden 1. Huawei Mate 10 Pro Battery Replacement, Battery: adım 8, 2 resimden 2.
    • Use a spudger to disconnect the battery flex cable.
    • Apply an iOpener on the screen for at least one minute to loosen the adhesive beneath the battery.
  9. Huawei Mate 10 Pro Battery Replacement: adım 9, 3 resimden 1. Huawei Mate 10 Pro Battery Replacement: adım 9, 3 resimden 2. Huawei Mate 10 Pro Battery Replacement: adım 9, 3 resimden 3.
    • The display flex cable runs underneath the battery. So be careful not do damage it when loosening the adhesive. Also take care not to bend or puncture the battery at any time.
    • Use a spudger to carefully pry up the battery and slide along the side to separate the adhesive.
    • Remove the battery.
    • When reassembling your phone replace the old adhesive with double-sided tape or pre-cut adhesive.
Sonuç
30 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
203.632 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
17.141 adet Kılavuz yazıldı
9 Yorum
complimento ottima guida
coroby - Yanıt
The battery was glued in really firmly. I ended up pulling it out with a plier and had some smoke and sparks, luckily I had made sure to drain it completely prior to repair.
Martin Olsson - Yanıt
Hi there, I completed the battery replacement nicely with all your steps, the phone could turn on and function normally, the only issue after the battery replacement is the phone has no sound and vibration. I have ensure all connectors are back to place securely. Does anyone have any clue of the cause of no sound and no vibration?
Shawn W - Yanıt
Geschafft! Okay, ich war sehr vorsichtig und extrem überlegt. (2 Stunden) Wichtig ist ein Test vor dem verschließen. Bei mir funktionierte der Lautsprecher nicht. Stecker für selbigen war aufgesteckt hatte aber keinen Kontakt. Nochmaliges festdrücken und seit dem ist alles iO. Achtung der Akku ist extrem fest verklebt. Nur mit viel Geduld, Kraft und Wärme war es überhaupt möglich ihn zu lösen. Mit den noch vorhanden Kleberresten im Deckel wieder verschlossen. Hat alles Geklappt und Danke nochmal an diese Super Beschreibung.
Andreas Fiedler - Yanıt
Sehr gute Anleitung. Ist unter 30 Mminuten gut zu machen wenn nicht wie bei mir der Akku schon gebläht gewesen ist…Dadurch war es deutlich schwieriger den Akku raus zu bekommen - Huawei hat wirklich einen irren Kleber verwendet. Muss aber sagen das Stecker usw wesentlich besser flutschen als bei Iphones. Alles in allem finde ich das Mate 10 pro wirklich reparaturfreundlich. Danke nochmals an den Autor für die gute Anleitung?
Torsten Berges - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 68
Son 30 gün: 228
Her zaman: 33,951
