Huawei Mate 8 Loudspeaker Replacement
Giriş
1. adıma gitUse this guide to replace the loudspeaker in your Huawei Mate 8.
Neye ihtiyacın var
Remove the liquid indicator sticker.
Remove the Phillips #00 screw that holds down the metal shield.
Use a spudger to remove the metal shield.
Remove the two Phillips #00 screws.
Use the flat end a spudger to disconnect the loudspeaker flex connector.
Use the pointy end of a spudger to pry out the daughterboard.
Remove the daughterboard.
Use the tip of a spudger on the left side of the loudspeaker to pry it out.
Remove the loudspeaker.
4 farklı kişi bu kılavuzu tamamladı.
