Ana içeriğe geç
Huawei P10 Battery Replacement
Neye ihtiyacın var
  1. Huawei P10 Battery Replacement, Back Cover: adım 1, 3 resimden 1. Huawei P10 Battery Replacement, Back Cover: adım 1, 3 resimden 2. Huawei P10 Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Battery Replacement: adım 2, 3 resimden 1. Huawei P10 Battery Replacement: adım 2, 3 resimden 2. Huawei P10 Battery Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Battery Replacement: adım 3, 2 resimden 1. Huawei P10 Battery Replacement: adım 3, 2 resimden 2.
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the two Phillips #00 screws.
  5. Huawei P10 Battery Replacement: adım 5, 2 resimden 1. Huawei P10 Battery Replacement: adım 5, 2 resimden 2.
    • Use tweezers to remove the two cable brackets.
  6. Huawei P10 Battery Replacement: adım 6, 3 resimden 1. Huawei P10 Battery Replacement: adım 6, 3 resimden 2. Huawei P10 Battery Replacement: adım 6, 3 resimden 3.
    • Use a spudger to disconnect the battery, the interconnect and the display flex cable.
  7. Huawei P10 Battery Replacement: adım 7, 2 resimden 1. Huawei P10 Battery Replacement: adım 7, 2 resimden 2.
    • The battery is glued in place with two adhesive strips. One with a pull tab and one without.
    • Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
    • It is likely that the adhesive strip rips. In this case you can grab and twist it around a tweezers tip a couple of times and then continue.
    • Use an iOpener to loosen the remaining adhesive.
  8. Huawei P10 Battery Replacement: adım 8, 2 resimden 1. Huawei P10 Battery Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    Tesa 61395 Tape
    $5.99
    Satın Al
    • Take care to not bend or puncture the battery.
    • Insert an opening pick or spudger beneath the battery and carefully pry it out.
    • Remove the battery.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
    • Never reinstall a battery that has been bent or damaged during removal.
Sonuç
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
75 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
203.353 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
16 Yorum
Thanks for posting this this give me new ideas.
Dave Dayanan - Yanıt
Facile comme bonjour. Les outils que j'avais reçu avec la batterie étaient de piètre qualité, j'ai donc utilisé des mini-spatules utilisées pour lisser les joints en silicone, c'est pile la consistance voulue pour décoller le dos et la batterie, ni trop ferme ni trop souple.
lepisosteus74 - Yanıt
Easy fix, thanks a lot.
Noé Barreau - Yanıt
Excellent guide, was done in 20 minutes, thankyou!
Mog Kupo - Yanıt
Eccellente guida peccato che una volta montata la nuova batteria in cellulare si sente che si accende la il display rimane buio, controllato connessioni ma sono tutte ok e display sempre spento, cosa può essere?
Adriano
Adriano Da Rold - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 80
Son 30 gün: 276
Her zaman: 64,598
