Ana içeriğe geç
Huawei P10 Plus Vibration Motor Replacement
  1. Huawei P10 Plus Vibration Motor Replacement, Display: adım 1, 3 resimden 1. Huawei P10 Plus Vibration Motor Replacement, Display: adım 1, 3 resimden 2. Huawei P10 Plus Vibration Motor Replacement, Display: adım 1, 3 resimden 3.
    • Use an iOpener to loosen the adhesive beneath the display, focusing on the upper and lower part of the display.
    • Use an opening pick, or iFlex, to separate the adhesive on all sides of the display.
    • To avoid damage to the display, do not push the tool too deeply into the phone.
  2. Huawei P10 Plus Vibration Motor Replacement: adım 2, 3 resimden 1. Huawei P10 Plus Vibration Motor Replacement: adım 2, 3 resimden 2. Huawei P10 Plus Vibration Motor Replacement: adım 2, 3 resimden 3.
    • There is a thin display cable between the screen and phone, be very careful not to rip it when opening the device.
    • Place a suction cup, or iSclack, on the upper portion of the phone and lift the display off the midframe.
    • Don't remove the display, the cable is trapped under a bracket screwed to the phone. You can flip the display to lay it down without straining the cable, or simply hold it in the next steps.
  3. Huawei P10 Plus Vibration Motor Replacement, Unfasten the screw: adım 3, 1 resimden 1.
    • Remove the 3.3 mm-long Phillips screw securing the display flex connector bracket.
    • Open the metal bracket that covers the display flex cable.
    • Use a spudger to disconnect the display flex cable.
    • Remove the display.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
  4. Huawei P10 Plus Vibration Motor Replacement, Midframe: adım 5, 2 resimden 1. Huawei P10 Plus Vibration Motor Replacement, Midframe: adım 5, 2 resimden 2.
    • Remove the 13 Phillips #00 screws.
    • Remove the metal shield which holds down the display flex connector.
  5. Huawei P10 Plus Vibration Motor Replacement: adım 6, 3 resimden 1. Huawei P10 Plus Vibration Motor Replacement: adım 6, 3 resimden 2. Huawei P10 Plus Vibration Motor Replacement: adım 6, 3 resimden 3.
    • Remove the SIM card tray.
    • Use the pointed end of a spudger to pry out the mid frame until you can get a good grip.
  6. Huawei P10 Plus Vibration Motor Replacement: adım 7, 3 resimden 1. Huawei P10 Plus Vibration Motor Replacement: adım 7, 3 resimden 2. Huawei P10 Plus Vibration Motor Replacement: adım 7, 3 resimden 3.
    • Remove the mid frame.
    • Disconnect the battery flex cable with a spudger.
  7. Huawei P10 Plus Vibration Motor Replacement, Charging Board: adım 8, 2 resimden 1. Huawei P10 Plus Vibration Motor Replacement, Charging Board: adım 8, 2 resimden 2.
    • Remove the three Phillips #000 screw.
    • Remove the metal shield covering the charging board with tweezers.
  8. Huawei P10 Plus Vibration Motor Replacement: adım 9, 3 resimden 1. Huawei P10 Plus Vibration Motor Replacement: adım 9, 3 resimden 2. Huawei P10 Plus Vibration Motor Replacement: adım 9, 3 resimden 3.
    • Use a spudger to disconnect the headphone jack flex cable, the loudspeaker flex cable and the main flex cable.
  9. Huawei P10 Plus Vibration Motor Replacement: adım 10, 3 resimden 1. Huawei P10 Plus Vibration Motor Replacement: adım 10, 3 resimden 2. Huawei P10 Plus Vibration Motor Replacement: adım 10, 3 resimden 3.
    • Unplug both antenna cables with tweezers.
    • Carefully remove the headphone jack.
    • The headphone jack might be a little bit sticky. In case you're having trouble removing it, use an iOpener to loosen the adhesive.
  10. Huawei P10 Plus Vibration Motor Replacement: adım 11, 2 resimden 1. Huawei P10 Plus Vibration Motor Replacement: adım 11, 2 resimden 2.
    • Use the pointed end of a spudger to pry off the charging board.
    • Remove the charging board.
  11. Huawei P10 Plus Vibration Motor Replacement, Vibration Motor: adım 12, 2 resimden 1. Huawei P10 Plus Vibration Motor Replacement, Vibration Motor: adım 12, 2 resimden 2.
    • Use an iOpener to loosen the adhesive beneath the vibration motor.
    • Remove the vibration motor.
Sonuç
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
172.614 İtibar
676 adet Kılavuz yazıldı
iFixit iFixit üyesi
Community
141 Üyeler
17.709 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 434
