Giriş
Use this guide to remove or replace a defective motherboard cover with NFC & charging coil in your Huawei P30 Pro.
Opening the Huawei P30 Pro will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Neye ihtiyacın var
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
If the adhesive becomes hard to cut, it most likely cooled down. Use your iOpener to reheat it.
Insert a fourth opening pick under the top left corner of the back cover.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Remove the ten Phillips #00 screws (4.3 mm length).
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Hallo,
erstmal Super Anleitung. Danke dafür.
Ich hätte noch ein paar Fragen. Und zwar ist mein Backcover von meinem Huawei P30 pro nach einem Sturz gebrochen. Ist es möglich, es selber auszuwechseln und dabei den Spritzwasserschutz, sprich den Schutz Ip68 zu erhalten? Und wenn ja, welchen Kleber sollte ich dafür verwenden? Auch wüsste ich gerne, ob es vielleicht reicht die Risse mit dem Kleber zu versiegeln, so dass ich das Backcover gar nicht austauschen muss!?
Sonnige Grüße
Rafael
