Ana içeriğe geç
Huawei P8 Lite Camera Replacement
Neye ihtiyacın var
  1. Huawei P8 Lite Camera Replacement, Camera: adım 1, 1 resimden 1.
    • Insert the SIM card eject tool into the small circular slots.
    • Apply slight pressure to pop the SIM card out, and remove it.
  2. Huawei P8 Lite Camera Replacement: adım 2, 1 resimden 1.
    • With your finger nails, spudger or other gentle tools, remove the back cover by wedging into the space and popping the edge free.
  3. Huawei P8 Lite Camera Replacement: adım 3, 1 resimden 1.
    • Remove three screws using a Phillips #000 screwdriver.
    • Remove four screws using a T5 Torx screwdriver.
  4. Huawei P8 Lite Camera Replacement: adım 4, 1 resimden 1.
    • Using your fingers, carefully unlatch and remove the connectors attached to the motherboard.
  5. Huawei P8 Lite Camera Replacement: adım 5, 1 resimden 1.
    • With your fingers, gently remove the motherboard and set aside.
  6. Huawei P8 Lite Camera Replacement: adım 6, 1 resimden 1.
    • With the spudger tool, gently lift the front camera from the motherboard.
  7. Huawei P8 Lite Camera Replacement: adım 7, 2 resimden 1. Huawei P8 Lite Camera Replacement: adım 7, 2 resimden 2.
    • Use the spudger to remove the rear camera.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Brayden Mann
639 İtibar
4 adet Kılavuz yazıldı
Ekip
Metro State, Team 1-2, Carpenter Spring 2016 Metro State, Team 1-2, Carpenter Spring 2016 üyesi
MSU-CARPENTER-S16S1G2
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 1,460
