Ana içeriğe geç
Huawei P8 Lite Earpiece Speaker Replacement
Neye ihtiyacın var
  1. Huawei P8 Lite Earpiece Speaker Replacement, Remove  Back Cover and Loudspeaker: adım 1, 2 resimden 1. Huawei P8 Lite Earpiece Speaker Replacement, Remove  Back Cover and Loudspeaker: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Spudger
    $2.99
    Satın Al
    • Use the Spudger tool to get access to the loudspeaker. Locate where the headphone jack is, then move about one-inch to the right and begin to gently pry the back-cover off the phone with the flat end of the Spudger tool. Make sure to pry apart the entire perimeter of the back-cover to prevent bending/cracking of the plastic.
    • Tools used: Spudger tool (used as a wedge to pry off the back-cover and loudspeaker.)
  2. Huawei P8 Lite Earpiece Speaker Replacement: adım 2, 1 resimden 1.
    • Remove three silver Phillips 000 screws.
    • Remove four T5 Torx screws.
  3. Huawei P8 Lite Earpiece Speaker Replacement: adım 3, 2 resimden 1. Huawei P8 Lite Earpiece Speaker Replacement: adım 3, 2 resimden 2.
    Spudger
    $2.99
    Satın Al
    • Gently, use the flat end of the Spudger tool, or a metal opening tool to lift and remove the loudspeaker from the phone. The loudspeaker is the entire portion of the phone where the screws were extracted.
  4. Huawei P8 Lite Earpiece Speaker Replacement, Earpiece Speaker: adım 4, 2 resimden 1. Huawei P8 Lite Earpiece Speaker Replacement, Earpiece Speaker: adım 4, 2 resimden 2.
    Satın Al
    • Use the tweezers to grip the earpiece speaker and lift the earpiece speaker from phone.
Sonuç
To reassemble your device, follow Teardown Guide steps 12, 6, 5, 4, 3, 2, 1 in that order.
Brayden Mann
639 İtibar
4 adet Kılavuz yazıldı
Ekip
Metro State, Team 1-2, Carpenter Spring 2016 Metro State, Team 1-2, Carpenter Spring 2016 üyesi
MSU-CARPENTER-S16S1G2
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 2,176
