Ana içeriğe geç
Huawei P8 Lite Motherboard Replacement
Neye ihtiyacın var
  1. Huawei P8 Lite Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Remove the SIM card tray.
    • Use the SIM Card Eject Tool to click the pins located in two small holes on the side of the phone.
  2. Huawei P8 Lite Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the back cover.
    • The cover is not fastened with screws or adhesive, so you can use your finger nails, plastic spudger or other tools.
  3. Huawei P8 Lite Motherboard Replacement: adım 3, 1 resimden 1.
    • Use the screwdrivers from 54 Bit Driver Kit to undo the screws. Be sure to keep the screws separated on your work surface to avoid confusion during the assembly.
    • PH000 Bit
    • T5 Torx
  4. Huawei P8 Lite Motherboard Replacement: adım 4, 1 resimden 1.
    • Gently pull the connectors attached to the motherboard to disconnect them. See the highlighted areas in the photos.
    • These connectors are extremely fragile, so avoid using any kind of tools and make sure to be extremely gentle in the process.
  5. Huawei P8 Lite Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the motherboard carefully.
    • Replace the motherboard with the new one. To reassempble the phone, follow the teardown process guide in the reverse order.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Brayden Mann
645 İtibar
4 adet Kılavuz yazıldı
Ekip
Metro State, Team 1-2, Carpenter Spring 2016 Metro State, Team 1-2, Carpenter Spring 2016 üyesi
MSU-CARPENTER-S16S1G2
3 Üyeler
8 adet Kılavuz yazıldı
4 Yorum
Anywhere to buy this motherboard? Maybe display as well?
Jan Šinkovec - Yanıt
mine also need a new mother
anywr l can get it asap
blessed - Yanıt
Hey
I need p8 lite motherboard
goitsemodimo - Yanıt
I had to resort to some tips on how to disassemble P8 LITE to change the micro usb charger. Thanks for sharing.
Alvaro Gomes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 8,198
