Ana içeriğe geç
Huawei P9 Lite Battery Replacement
Neye ihtiyacın var
    1. Huawei P9 Lite Battery Replacement, Back Cover: adım 1, 2 resimden 1. Huawei P9 Lite Battery Replacement, Back Cover: adım 1, 2 resimden 2.
      • Use an opening pick to unclip the rear cover, starting from the bottom corner.
      • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
      FixBot'a Sor
      Yorum Ekle
    2. Huawei P9 Lite Battery Replacement: adım 2, 1 resimden 1.
      • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
      • Be careful with the flex cable at the right hand side.
      • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
      FixBot'a Sor
      Yorum Ekle
    3. Huawei P9 Lite Battery Replacement: adım 3, 1 resimden 1.
      • When the back cover is freed from the adhesive you can pop it off by hand completely.
      FixBot'a Sor
      Yorum Ekle
    1. Huawei P9 Lite Battery Replacement, Loudspeaker: adım 4, 3 resimden 1. Huawei P9 Lite Battery Replacement, Loudspeaker: adım 4, 3 resimden 2. Huawei P9 Lite Battery Replacement, Loudspeaker: adım 4, 3 resimden 3.
      • On the bottom of the phone remove the following screws:
      • Three 2.9 mm Phillips #00 screws
      • Four 3.8 mm Phillips #00 screws
      • Now you can grab the loudspeaker unit and take it out.
      FixBot'a Sor
      Yorum Ekle
    1. Huawei P9 Lite Battery Replacement, Motherboard Shield: adım 5, 1 resimden 1.
      • Remove the nine Phillips #00 screws that secure the metal shield plate.
      • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
      FixBot'a Sor
      Yorum Ekle
    2. Huawei P9 Lite Battery Replacement: adım 6, 2 resimden 1. Huawei P9 Lite Battery Replacement: adım 6, 2 resimden 2.
      • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
      • Use a spudger to disconnect the fingerprint sensor from the motherboard.
      • Peel the NFC antenna cable off of the metal plate.
      FixBot'a Sor
      Yorum Ekle
    1. Huawei P9 Lite Battery Replacement, Battery: adım 7, 3 resimden 1. Huawei P9 Lite Battery Replacement, Battery: adım 7, 3 resimden 2. Huawei P9 Lite Battery Replacement, Battery: adım 7, 3 resimden 3.
      • Disconnect the motherboard flex cable on both ends and take it away.
      FixBot'a Sor
      Yorum Ekle
    2. Huawei P9 Lite Battery Replacement: adım 8, 2 resimden 1. Huawei P9 Lite Battery Replacement: adım 8, 2 resimden 2.
      • Peel off the NFC antenna from the battery.
      • Be careful not to rip or crease the antenna.
      • If you are just removing the battery to get to the display, you can leave the NFC on the battery.
      • Unplug the battery connector.
      FixBot'a Sor
      Yorum Ekle
    3. Huawei P9 Lite Battery Replacement: adım 9, 3 resimden 1. Huawei P9 Lite Battery Replacement: adım 9, 3 resimden 2. Huawei P9 Lite Battery Replacement: adım 9, 3 resimden 3.
      Bu adımda kullanılan alet:
      Tesa 61395 Tape
      $8.95
      • Slide the spudger under the battery at the place shown in the picture and pry it loose slowly.
      • Avoid bending the battery and reheat if necessary.
      • Be careful not to damage the display flex cable that runs underneath the battery in the center.
      • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
      FixBot'a Sor
      Yorum Ekle
Sonuç
89 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
134.625 İtibar
189 adet Kılavuz yazıldı
Ekip
26Kılavuz Yorumları
There is an extra step where you need to remove the cover of the board at the top of the phone in order to remove the NFC antenna which is not described in this guide. Better watch this https://www.youtube.com/watch?v=ADZiL7JK...
Costas Geraniou - Yanıt Paylaş
Thanks Costas for the hint. We added the missing step.
Tobias Isakeit - Yanıt Paylaş
Very very thanks!
Artur - Yanıt Paylaş
Cercando di rimouorere l'adesivo dell'nfc si è rotto, posso assembrale il telefono senza nfc, ovviamente invalidando questa funzione?
Francesco Staiano - Yanıt Paylaş
Si, hai ragione: si può riassemblare il telefono senza l’antenna NFC perdendo questa funzione…
Claire Miesch - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 146
Her zaman: 137,666
