Giriş
Use this guide to replace the front camera in your Huawei P9 Lite.
Neye ihtiyacın var
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Remove the nine Phillips #00 screws that secure the metal shield plate.
Disconnect the front camera flex from the motherboard.
Flip the motherboard over and thread the flex cable through the opening and take the camera away.
5 farklı kişi bu kılavuzu tamamladı.
