Ana içeriğe geç
Husqvarna Viking Designer 1 Needle Replacement
Neye ihtiyacın var
  1. Husqvarna Viking Designer 1 Needle Replacement, Needle: adım 1, 2 resimden 1. Husqvarna Viking Designer 1 Needle Replacement, Needle: adım 1, 2 resimden 2.
    • Remove the thread from the needle by pulling it out.
  2. Husqvarna Viking Designer 1 Needle Replacement: adım 2, 3 resimden 1. Husqvarna Viking Designer 1 Needle Replacement: adım 2, 3 resimden 2. Husqvarna Viking Designer 1 Needle Replacement: adım 2, 3 resimden 3.
    • Turn the knob counterclockwise to life up the needle.
    • Turning the knob clockwise can damage the machine.
  3. Husqvarna Viking Designer 1 Needle Replacement: adım 3, 1 resimden 1.
    • Place a sheet of paper under the foot. In the event that the needle falls out, this will prevent it from falling into the bobbin area.
  4. Husqvarna Viking Designer 1 Needle Replacement: adım 4, 2 resimden 1. Husqvarna Viking Designer 1 Needle Replacement: adım 4, 2 resimden 2.
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to loosen the needle clamp screw (model: Viking #4125825-01) located next to the top of the needle with the other hand.
  5. Husqvarna Viking Designer 1 Needle Replacement: adım 5, 1 resimden 1.
    • Discard the broken or unwanted needle, and select a new one.
  6. Husqvarna Viking Designer 1 Needle Replacement: adım 6, 2 resimden 1. Husqvarna Viking Designer 1 Needle Replacement: adım 6, 2 resimden 2.
    • Insert the new needle with the flat side facing away from you.
  7. Husqvarna Viking Designer 1 Needle Replacement: adım 7, 1 resimden 1.
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to tighten the needle clamp screw (model: Viking #4125825-01) with the other hand.
  8. Husqvarna Viking Designer 1 Needle Replacement: adım 8, 1 resimden 1.
    • Thread the needle. (See pages 8-10 from the link.)
    • You may now remove the sheet of paper and begin sewing!
Sonuç
Replacing the needle is a quick, easy task to complete, using the directions provided in this guide.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Excellent illustration!!!
KO SAMUEL TAK SHUN - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 35
Her zaman: 1,324
