Ana içeriğe geç
HyperX Alloy Origins Toggle Indicator Tab Replacement
Neye ihtiyacın var
  1. HyperX Alloy Origins Toggle Indicator Tab Replacement, Toggle Indicator Tab: adım 1, 1 resimden 1.
    • Locate the toggle indicator tab on the top right corner of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  2. HyperX Alloy Origins Toggle Indicator Tab Replacement: adım 2, 2 resimden 1. HyperX Alloy Origins Toggle Indicator Tab Replacement: adım 2, 2 resimden 2.
    • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
    • Lift up gently on the tab, while holding the left side of the tab down.
    • The tab can spring upwards upon removal. Eye protection is recommended during this step.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Adam Sles
310 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G2
5 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
Hello! Do I have to forcefully press down the tab? If it starts to bend, should I continue to hold it?
Lorkhall - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 964
