Ana içeriğe geç
HyperX Cloud Alpha Headband Replacement
Neye ihtiyacın var
  1. HyperX Cloud Alpha Headband Replacement, Headband: adım 1, 1 resimden 1.
    • Remove the two Phillips #1 screws from the clips located on the headband.
    • Repeat on the other clip. (If you did the right side first, then do the left and vice-versa.)
  2. HyperX Cloud Alpha Headband Replacement: adım 2, 1 resimden 1.
    • Remove the black plastic clips, freeing the metal sliding band inside.
  3. HyperX Cloud Alpha Headband Replacement: adım 3, 3 resimden 1. HyperX Cloud Alpha Headband Replacement: adım 3, 3 resimden 2. HyperX Cloud Alpha Headband Replacement: adım 3, 3 resimden 3.
    • Remove the worn band.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Ekip
UMass Dartmouth, Team 5-4, Sinclaire Fall 2022 UMass Dartmouth, Team 5-4, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G4
5 Üyeler
8 adet Kılavuz yazıldı
3Kılavuz Yorumları
¿Y qué hago con el cable que cruza dentro de la almohadilla? No puedo reemplazarlo si este está cruzado entre los dos extremos del auricular y dentro de la almohadilla misma.
Daniel Cetina Bastida - Yanıt Paylaş
This guide feels like it's missing several steps. I tried taking apart the HyperX Cloud 1 which is put together pretty much the same way. As you show in Step 2 there's a cable that runs through the headband that connects the left cup to the right cup. If your goal is to replace a worn headband, you would basically have to disconnect the cable from one of the cups which is a soldered connection, draw it out through the headband, thread it back through your replacement headband, and re-solder the cable to the cup, no? That seems like an important omission.
In my case I have no soldering skills so I opted to just cut the old headband open to get the cable free, then I put it back together with just the metal sliding band and no headband.
Terry - Yanıt Paylaş
This is just full wrong and missleading. You need to solder things to replace headband
Stanislav Shostak - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 52
Son 30 gün: 318
Her zaman: 12,424
