Ana içeriğe geç
IQ America VD-8810L Motherboard Replacement
Neye ihtiyacın var
  1. IQ America VD-8810L Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. IQ America VD-8810L Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. IQ America VD-8810L Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Wedge the spudger into the slot of the panel on the bottom of the device.
    • Rotate out the panel to reveal the screw holding the device together.
  2. IQ America VD-8810L Motherboard Replacement: adım 2, 2 resimden 1. IQ America VD-8810L Motherboard Replacement: adım 2, 2 resimden 2.
    • Use the Phillips head screwdriver to remove the screw.
    • Separate the Top and bottom halves of the device.
  3. IQ America VD-8810L Motherboard Replacement: adım 3, 3 resimden 1. IQ America VD-8810L Motherboard Replacement: adım 3, 3 resimden 2. IQ America VD-8810L Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove batteries from the battery slot.
    • Unscrew the two Phillips head screws in the center of the battery slot.
    • Unscrew the remaining two screws at the bottom of the unit using the 3.0 triangle head screwdriver.
  4. IQ America VD-8810L Motherboard Replacement: adım 4, 1 resimden 1.
    • Use the spudger to separate the top and bottom halves of the screen.
  5. IQ America VD-8810L Motherboard Replacement: adım 5, 1 resimden 1.
    • Disconnect the wires from the green motherboard to the bottom half by pulling apart the connecting pins.
  6. IQ America VD-8810L Motherboard Replacement: adım 6, 3 resimden 1. IQ America VD-8810L Motherboard Replacement: adım 6, 3 resimden 2. IQ America VD-8810L Motherboard Replacement: adım 6, 3 resimden 3.
    • Unscrew all 3 Phillips head screws on the outside edges of the motherboard.
  7. IQ America VD-8810L Motherboard Replacement: adım 7, 1 resimden 1.
    • Carefully remove the microphone from the casing by pulling away from the device.
  8. IQ America VD-8810L Motherboard Replacement: adım 8, 2 resimden 1. IQ America VD-8810L Motherboard Replacement: adım 8, 2 resimden 2.
    • Gently lift the motherboard from the casing to reveal the speaker.
    • Unscrew the two Phillips head screws that hold the speaker in place.
  9. IQ America VD-8810L Motherboard Replacement: adım 9, 1 resimden 1.
    • Refer to this guide to desolder the speaker from the motherboard.
Sonuç
Jackey Lau
301 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 222
