Ana içeriğe geç
IdeaPad L340-15API Optical Drive Replacement
Neye ihtiyacın var
  1. IdeaPad L340-15API Optical Drive Replacement, Optical Drive: adım 1, 2 resimden 1. IdeaPad L340-15API Optical Drive Replacement, Optical Drive: adım 1, 2 resimden 2.
    • Before beginning the repair, make sure that the device is fully powered off.
    • Turn the laptop over so the bottom cover is facing up.
    • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
    FixBot'a Sor
    Yorum Ekle
  2. IdeaPad L340-15API Optical Drive Replacement: adım 2, 2 resimden 1. IdeaPad L340-15API Optical Drive Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
    • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
    FixBot'a Sor
    Yorum Ekle
  3. IdeaPad L340-15API Optical Drive Replacement: adım 3, 2 resimden 1. IdeaPad L340-15API Optical Drive Replacement: adım 3, 2 resimden 2.
    • Place your thumb at the seam between the optical drive and the device.
    • Gently pull the component straight out from the device, taking care not to pull at an angle.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
Ian
347 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-5, Bowman Fall 2025 UMass Dartmouth, Team 2-5, Bowman Fall 2025 üyesi
UMASSD-BOWMAN-F25S2G5
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 168
