Ana içeriğe geç
IdeaPad L340-15API RAM Replacement
Neye ihtiyacın var
  1. IdeaPad L340-15API RAM Replacement, Optical Drive: adım 1, 2 resimden 1. IdeaPad L340-15API RAM Replacement, Optical Drive: adım 1, 2 resimden 2.
    • Before beginning the repair, make sure that the device is fully powered off.
    • Turn the laptop over so the bottom cover is facing up.
    • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
    FixBot'a Sor
    Yorum Ekle
  2. IdeaPad L340-15API RAM Replacement: adım 2, 2 resimden 1. IdeaPad L340-15API RAM Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
    • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
    FixBot'a Sor
    Yorum Ekle
  3. IdeaPad L340-15API RAM Replacement: adım 3, 2 resimden 1. IdeaPad L340-15API RAM Replacement: adım 3, 2 resimden 2.
    • Place your thumb at the seam between the optical drive and the device.
    • Gently pull the component straight out from the device, taking care not to pull at an angle.
    FixBot'a Sor
    Yorum Ekle
  4. IdeaPad L340-15API RAM Replacement, Battery: adım 4, 2 resimden 1. IdeaPad L340-15API RAM Replacement, Battery: adım 4, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
    FixBot'a Sor
    Yorum Ekle
  5. IdeaPad L340-15API RAM Replacement: adım 5, 3 resimden 1. IdeaPad L340-15API RAM Replacement: adım 5, 3 resimden 2. IdeaPad L340-15API RAM Replacement: adım 5, 3 resimden 3.
    • Insert a plastic opening pick in the back left corner and wedge the panel open.
    • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
    • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
    • Remove the bottom cover.
    FixBot'a Sor
    Yorum Ekle
  6. IdeaPad L340-15API RAM Replacement: adım 6, 2 resimden 1. IdeaPad L340-15API RAM Replacement: adım 6, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
    • Use a container/magnet strip to store the screws while working.
    FixBot'a Sor
    Yorum Ekle
  7. IdeaPad L340-15API RAM Replacement: adım 7, 3 resimden 1. IdeaPad L340-15API RAM Replacement: adım 7, 3 resimden 2. IdeaPad L340-15API RAM Replacement: adım 7, 3 resimden 3.
    • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
    FixBot'a Sor
    Yorum Ekle
  8. IdeaPad L340-15API RAM Replacement: adım 8, 1 resimden 1.
    • Remove the battery from the laptop.
    FixBot'a Sor
    Yorum Ekle
  9. IdeaPad L340-15API RAM Replacement, RAM: adım 9, 3 resimden 1. IdeaPad L340-15API RAM Replacement, RAM: adım 9, 3 resimden 2. IdeaPad L340-15API RAM Replacement, RAM: adım 9, 3 resimden 3.
    • Lift the metal cover next to the heat sink to reveal the RAM.
    FixBot'a Sor
    Yorum Ekle
  10. IdeaPad L340-15API RAM Replacement: adım 10, 3 resimden 1. IdeaPad L340-15API RAM Replacement: adım 10, 3 resimden 2. IdeaPad L340-15API RAM Replacement: adım 10, 3 resimden 3.
    • Using your fingers or a spudger, spread the clips away from the RAM module.
    • Be careful not to pull too hard and damage the metal arms.
    • When released, the RAM module will pop up at a slight angle.
    • Lift the RAM module to an angle of about 30 degrees and slide it out.
    • When handling the RAM module, only touch the outside edges. Take care not to touch the gold-colored contact points along the bottom edge.
    • To install a new RAM module, insert it at about the same angle until it fits securely, then gently press it downward until the clips click into place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
Jasmyn
205 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-5, Bowman Fall 2025 UMass Dartmouth, Team 2-5, Bowman Fall 2025 üyesi
UMASSD-BOWMAN-F25S2G5
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 188
