Ana içeriğe geç
Infant Optics DXR-5 Mother Board Replacement
Neye ihtiyacın var
  1. Infant Optics DXR-5 Mother Board Replacement, Battery: adım 1, 2 resimden 1. Infant Optics DXR-5 Mother Board Replacement, Battery: adım 1, 2 resimden 2.
    • Press on the blue clip on the back and slide it down.
    • In the second picture there is a slight gap at the top of the blue clip.
  2. Infant Optics DXR-5 Mother Board Replacement: adım 2, 1 resimden 1.
    • Pull the blue clip away from the body of the hand held monitor.
  3. Infant Optics DXR-5 Mother Board Replacement: adım 3, 1 resimden 1.
    • Slide the rear white panel off as shown.
  4. Infant Optics DXR-5 Mother Board Replacement: adım 4, 2 resimden 1. Infant Optics DXR-5 Mother Board Replacement: adım 4, 2 resimden 2.
    • Remove the battery by pushing in on the right side and then pulling the battery up and out of the body of the hand held monitor.
  5. Infant Optics DXR-5 Mother Board Replacement, Monitor Screen: adım 5, 3 resimden 1. Infant Optics DXR-5 Mother Board Replacement, Monitor Screen: adım 5, 3 resimden 2. Infant Optics DXR-5 Mother Board Replacement, Monitor Screen: adım 5, 3 resimden 3.
    • Remove the four 6.0 mm Phillips screws located on the back of the hand held monitor using a Phillips #2 screwdriver.
    • There are two types of screws. Be sure to return the screws to their respective holes upon reassembly.
  6. Infant Optics DXR-5 Mother Board Replacement: adım 6, 2 resimden 1. Infant Optics DXR-5 Mother Board Replacement: adım 6, 2 resimden 2.
    • Carefully remove the clear face plate on the front of the hand held monitor using a plastic spudger and a suction cup.
    • Use a heat source to loosen the adhesive around the edge of the face plate before applying any pressure to the face plate.
  7. Infant Optics DXR-5 Mother Board Replacement: adım 7, 2 resimden 1. Infant Optics DXR-5 Mother Board Replacement: adım 7, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the two 6.0 mm Phillips screws that are exposed after removing the face plate.
  8. Infant Optics DXR-5 Mother Board Replacement: adım 8, 2 resimden 1. Infant Optics DXR-5 Mother Board Replacement: adım 8, 2 resimden 2.
    • Using a drill carefully drill out the plastic posts that connect the mother board to the face plate.
  9. Infant Optics DXR-5 Mother Board Replacement: adım 9, 2 resimden 1. Infant Optics DXR-5 Mother Board Replacement: adım 9, 2 resimden 2.
    • Carefully open the hand held monitor and flip the screen (highlighted in red) out of the way.
  10. Infant Optics DXR-5 Mother Board Replacement: adım 10, 2 resimden 1. Infant Optics DXR-5 Mother Board Replacement: adım 10, 2 resimden 2.
    • Remove the hand held monitor screen from the mother board by carefully pulling from the point where it is attached with an adhesive to the mother board.
  11. Infant Optics DXR-5 Mother Board Replacement, Mother Board: adım 11, 1 resimden 1.
    • Using a soldering iron remove the leads from the speaker on the front plate of the hand held monitor.
    • The leads must be put back in the correct order.
  12. Infant Optics DXR-5 Mother Board Replacement: adım 12, 2 resimden 1. Infant Optics DXR-5 Mother Board Replacement: adım 12, 2 resimden 2.
    • Remove the adhesive around the antenna wire.
    • Remove the antenna wire from the back plate of the hand held monitor.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Charles Neal
687 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-2, Remmell Fall 2015 USF Tampa, Team 6-2, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S6G2
5 Üyeler
Bir Yorum
Great pictures! They enabled me to find the two hidden screws. I removed them (and the other obvious screws) and then bent charging pin back to intended position. The monitor is now charging again! Thanks!!
michael_a_hahn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,424
