Ana içeriğe geç
Infant Optics DXR-8 Monitor Motherboard Replacement
Neye ihtiyacın var
  1. Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: adım 1, 3 resimden 1. Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: adım 1, 3 resimden 2. Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: adım 1, 3 resimden 3.
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Monitor Motherboard Replacement: adım 2, 3 resimden 1. Infant Optics DXR-8 Monitor Motherboard Replacement: adım 2, 3 resimden 2. Infant Optics DXR-8 Monitor Motherboard Replacement: adım 2, 3 resimden 3.
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Monitor Motherboard Replacement: adım 3, 3 resimden 1. Infant Optics DXR-8 Monitor Motherboard Replacement: adım 3, 3 resimden 2. Infant Optics DXR-8 Monitor Motherboard Replacement: adım 3, 3 resimden 3.
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: adım 4, 3 resimden 1. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: adım 4, 3 resimden 2. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: adım 4, 3 resimden 3.
    • Using a plastic opening tool, disconnect the ribbon cable connector.
    • Gently separate the ribbon cable from the motherboard.
  5. Infant Optics DXR-8 Monitor Motherboard Replacement: adım 5, 2 resimden 1. Infant Optics DXR-8 Monitor Motherboard Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the four 4mm screws around the edge of the motherboard.
    • Flip the motherboard away from the front case to reveal the screen on the other side.
  6. Infant Optics DXR-8 Monitor Motherboard Replacement: adım 6, 1 resimden 1.
    • Using a plastic opening tool, carefully pry the top retaining frame off of the screen. Start in one corner and work around the bottom of the frame.
  7. Infant Optics DXR-8 Monitor Motherboard Replacement: adım 7, 3 resimden 1. Infant Optics DXR-8 Monitor Motherboard Replacement: adım 7, 3 resimden 2. Infant Optics DXR-8 Monitor Motherboard Replacement: adım 7, 3 resimden 3.
    • Using a plastic opening pick, carefully pry a corner of the screen away from the motherboard.
    • Lift the screen off of the motherboard.
  8. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Motherboard: adım 8, 2 resimden 1. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Motherboard: adım 8, 2 resimden 2.
    • Flip the motherboard away from the case.
    • Using a soldering iron and desoldering braid, desolder the antenna from the motherboard.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Can you do one for the DXR-8 Pro monitor? Mine randomly stoped turning on and I want to see if I can open it up and try to fix it.
Andfel - Yanıt
Can you please tell me where to buy a replacement motherboard??
Ilya Nechay - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 1,094
