Ana içeriğe geç
Insignia Flex 10.1 Microphone Replacement
Neye ihtiyacın var
  1. Insignia Flex 10.1 Microphone Replacement, Microphone: adım 1, 1 resimden 1.
    • Please be aware that removing the rear panel from the back of the Flex 10.1 may cause damage to the rear panel.
  2. Insignia Flex 10.1 Microphone Replacement: adım 2, 2 resimden 1. Insignia Flex 10.1 Microphone Replacement: adım 2, 2 resimden 2.
    • The rear panel is secured to the front case by 26 clips attached to the rear panel. These clips lock onto small tabs machined into the front case.
    • To free the tabs, they must be pushed toward the center of the device. When using the plastic opening tool to free the rear panel, be sure to work the tool at the location of these clips.
    • To help in visualization, the 9 clips boxed in red are located on the same side as the volume buttons.
    • Remove back cover by inserting a plastic opening tool along the edge of the device to release the clips.
  3. Insignia Flex 10.1 Microphone Replacement: adım 3, 1 resimden 1.
    • Opening the Flex 10.1 can be challenging. Don't get discouraged if it takes multiple attempts before the Flex 10.1 is opened.
    • Insert the plastic opening tool into the seam between the front case and the rear panel of the Flex 10.1.
    • Gently enlarge the existing gap by pressing and wiggling the plastic opening tool into the gap near each of the clips attached to the rear case, pushing the clips toward the center of the device until the clips have been freed.
    • Repeat the same procedure to free all clips around the Flex 10.1.
  4. Insignia Flex 10.1 Microphone Replacement: adım 4, 1 resimden 1.
    • After ensuring all clips are free, separate the two halves of the Flex 10.1.
    • The rear panel is now free from the Flex 10.1.
  5. Insignia Flex 10.1 Microphone Replacement: adım 5, 1 resimden 1.
    • With the rear panel removed, the back side of the Flex 10.1 should look like this.
  6. Insignia Flex 10.1 Microphone Replacement: adım 6, 3 resimden 1. Insignia Flex 10.1 Microphone Replacement: adım 6, 3 resimden 2. Insignia Flex 10.1 Microphone Replacement: adım 6, 3 resimden 3.
    • Using the plastic opening tool or your fingers, remove the tape holding the black and red wires down.
    • The motherboard is a sensitive area of the device, so be careful to not scratch it when removing the tape.
  7. Insignia Flex 10.1 Microphone Replacement: adım 7, 3 resimden 1. Insignia Flex 10.1 Microphone Replacement: adım 7, 3 resimden 2. Insignia Flex 10.1 Microphone Replacement: adım 7, 3 resimden 3.
    • Gently remove microphone cover by holding the wire and pulling the cover off.
    • The microphone is enclosed by a black silicone cover.
  8. Insignia Flex 10.1 Microphone Replacement: adım 8, 2 resimden 1. Insignia Flex 10.1 Microphone Replacement: adım 8, 2 resimden 2.
    • The next few steps require a soldering iron.
    • Those who are new to soldering may want to check out iFixit's soldering technique guide. How To Solder and Desolder Connections.
    • Due to the fragile nature of electronic components, it is important to limit the amount of heat transferred from the soldering iron to the motherboard. A simple way to accomplish this is to pull the two wires with gentle continuous tension while the soldering iron heats up the connection.
    • The microphone is connected to the motherboard by a red and black wire.
    • Begin by heating up the two solder joints on the motherboard one at a time.
    • When the solder melts and the wire is free from the motherboard, immediately lift the solder tip off the connection to avoid damage.
  9. Insignia Flex 10.1 Microphone Replacement: adım 9, 1 resimden 1.
    • The microphone is now free from the motherboard.
  10. Insignia Flex 10.1 Microphone Replacement: adım 10, 1 resimden 1.
    • Solder the replacement microphone to the same joints on the motherboard.
    • Solder the connection by momentarily placing the tip of the soldering iron against the connection, pressing solder into the connection (melting it), and quickly removing both the solder and the tip of the soldering iron from the connection. The solder should flow around the wire and motherboard for a successful connection.
    • The black wire must be soldered to the negative joint.
    • The red wire must be soldered to the positive joint.
    • The positive and negative signs are indicated on the motherboard as well as in the picture.
Sonuç
Richard
455 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Isaacson Spring 2016 UMass Dartmouth, Team 2-1, Isaacson Spring 2016 üyesi
UMASSD-ISAACSON-S16S2G1
3 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 532
