Ana içeriğe geç
Insignia Flex 10.1 NS-P10A6100 Speakers Replacement
Neye ihtiyacın var
  1. Insignia Flex 10.1 NS-P10A6100 Speakers Replacement, Back Case: adım 1, 1 resimden 1.
    • Make sure your tablet is turned off and not connected to a power source to prevent personal injury.
    • The volume rocker and power button located on the top edge by the camera are not connected pieces and will become free from the device once the front panel is removed from the back case. They are easily put back in place when reassembling the tablet.
    • Position the tablet with the top edge by the camera facing down.
    • Insert the plastic opening tool between the front panel and back case at the upper left hand corner of the tablet.
  2. Insignia Flex 10.1 NS-P10A6100 Speakers Replacement: adım 2, 2 resimden 1. Insignia Flex 10.1 NS-P10A6100 Speakers Replacement: adım 2, 2 resimden 2.
    • Slide the plastic opening tool along the edge of the tablet between the front panel and back case.
    • Repeat this process for the two shorter edges of the tablet leaving the top edge by the camera still snapped in place.
  3. Insignia Flex 10.1 NS-P10A6100 Speakers Replacement: adım 3, 1 resimden 1.
    • Using an unfolding motion along the top edge of the tablet, carefully separate the front panel from the back case.
  4. Insignia Flex 10.1 NS-P10A6100 Speakers Replacement, Speakers: adım 4, 3 resimden 1. Insignia Flex 10.1 NS-P10A6100 Speakers Replacement, Speakers: adım 4, 3 resimden 2. Insignia Flex 10.1 NS-P10A6100 Speakers Replacement, Speakers: adım 4, 3 resimden 3.
    • Using the Phillips #000 screw driver, unscrew the four 4 mm screws securing the speakers to the front panel in a counterclockwise direction.
    • The four screws are very small, so be careful not to lose them after unscrewing them.
  5. Insignia Flex 10.1 NS-P10A6100 Speakers Replacement: adım 5, 1 resimden 1.
    • Unhook the woven red and black wires from the plastic hooks that hold them in place against the front panel
  6. Insignia Flex 10.1 NS-P10A6100 Speakers Replacement: adım 6, 1 resimden 1.
    • Desoldering can cause fumes that are dangerous to breathe in, and materials may be hot.
    • Desolder the four joints connecting the red and black wires from the speakers to the motherboard.
    • A thorough guide including step by step instructions on how to solder and desolder can be found here.
Sonuç
The speakers are now free from the device and can be replaced. To reassemble your device, follow these instructions in reverse order.
Samantha Damewood
961 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-8, Williams Fall 2016 Baylor, Team 5-8, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S5G8
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 692
