Giriş
If your tablet is not producing sound, or the sound is distorted or fuzzy, you may need to replace the speakers. This repair requires soldering, which can create dangerous fumes. Do not breathe in soldering fumes, and be careful around hot materials.
Neye ihtiyacın var
Position the tablet with the top edge by the camera facing down.
Insert the plastic opening tool between the front panel and back case at the upper left hand corner of the tablet.
Using the Phillips #000 screw driver, unscrew the four 4 mm screws securing the speakers to the front panel in a counterclockwise direction.
The speakers are now free from the device and can be replaced. To reassemble your device, follow these instructions in reverse order.
