Ana içeriğe geç
Insignia Flex 11.6 Battery Replacement
Neye ihtiyacın var
  1. Insignia Flex 11.6 Battery Replacement, Battery: adım 1, 3 resimden 1. Insignia Flex 11.6 Battery Replacement, Battery: adım 1, 3 resimden 2. Insignia Flex 11.6 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Before working on the device, make sure the device is off and not plugged into any power source for safety reasons. Failure to comply could result in injury.
    • Detach the keyboard from the screen in 2 different places by putting one hand on the keyboard while gently pulling up on the screen with the other hand.
  2. Insignia Flex 11.6 Battery Replacement: adım 2, 2 resimden 1. Insignia Flex 11.6 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the two 6.1 mm Phillips J000 screws from the bottom of the device. Use Phillips Screwdriver size J1.
    • If any screws are stripped, refer to the iFixit guide for how to remove a stripped screw.
  3. Insignia Flex 11.6 Battery Replacement: adım 3, 3 resimden 1. Insignia Flex 11.6 Battery Replacement: adım 3, 3 resimden 2. Insignia Flex 11.6 Battery Replacement: adım 3, 3 resimden 3.
    • Using a plastic opening tool, gently pry off the back cover.
  4. Insignia Flex 11.6 Battery Replacement: adım 4, 3 resimden 1. Insignia Flex 11.6 Battery Replacement: adım 4, 3 resimden 2. Insignia Flex 11.6 Battery Replacement: adım 4, 3 resimden 3.
    • Remove the electrical connector that connects to the battery to remove the power to the battery.
  5. Insignia Flex 11.6 Battery Replacement: adım 5, 3 resimden 1. Insignia Flex 11.6 Battery Replacement: adım 5, 3 resimden 2. Insignia Flex 11.6 Battery Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    Satın Al
    • Make sure not to bend the battery too excessively as if bent too much, it could rupture a cell within the battery and possibly cause a fire.
    • The battery is glued onto the device. To remove it, use a nylon spudger or plastic card to slide underneath the battery and scrape back and forth to remove the glue until the battery is removed from the device.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Donde puedo adquirir la batería?
arag12 - Yanıt
There are no screws on the bottom edge of my invicta model P11A8100. Can I bypass removing screws and proceed to removing the back?
Robert Sandfort - Yanıt
There are no screws on the bottom of my model P11A8100. Can I bypass removal is said screws and proceed to opening the back?
Great instructions but I cant find a battery replacement. Battery number 3394122-2p
Hank Drabczak - Yanıt
Great instructions but now I cant find the battery anywhere it is 3394122-2p
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 4,620
